Question about Vacuums
Repairing the idler arm assy model U6445 Windtunnel upright with bag
My Hoover Windtunnel upright Idler arm assy. part number U6445 has crack running through it. So I ordered the part from a hoover dealer and it was shipped without instrutions on how to take out the crack idler and to replace the new idler arm assy. I have tried to get help help from Hoover. hopeless. Maybe you guys can help. thanks. Cindy G. from Gendive Mt. P.S. It is a long way to drive to find a Hoover repair person in our area.my email is outback@midrivers.com
  • 294 Answers
SOURCE: Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Posted on Feb 28, 2009
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
SOURCE: Hoover windtunnel vaccum U6445-900 motor not
There are a number of Hoover vacuums that are subject to a recall due to an overheating on/off switch. Check out this web site to see if your is included. You'll need the model number and serial number from the back of the unit. The manufacturer will direct you to an authorized repair center for a free replacement of the defective switch.
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05156.html
Posted on Nov 02, 2009
  • 36 Answers
SOURCE: how can I repair the
If the slector it-self is broken It's very simple to fix. If your a do it yourselfer just go or contact any vacuum repair shop and ask for that part. Or call one and sometimes they will ship it to you. If you can't find any help contact vacs.etc@live.com and we can help you.
Posted on Nov 14, 2009
Is the brush always supposed to turn, even when upright?
I have a similar Hoover upright and the brush roller continues to revolve even with the handle locked and the hose detached for direct pickup. Seems rather odd to wear out the carpet that way.
Apr 06, 2016 | Hoover U6485900 Bagged Upright Vacuum
Hoover model U6425-900 brushes do not roll
-- Make sure slide switch is in carpet position
-- The idler arn which tensions the brush belt may be broken
-- The idler arm override which is attached to the carpet slide switch may be broken
The second one is common.
Oct 30, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover WindTunnel Model # U6445-900. The on/off switch needs to be replaced and I'm not sure what parts are needed to repair it. Thanks Gloria
You can order any parts needed at the below link. This is a parts diagram. The switch kit doesn't have a part number here, but it's the second item on the list.
http://www.fiorijanitorial.com/p-447-hoover-windtunnel-parts-self-propelled-body-u6423-900-u6425-900-u6425-920-u6431-900-u6445-900.aspx
I recommend using the below site to order. It provides a clear picture of the switch kit.
http://www.sweeper-city.com/howiswkit.html
Mar 16, 2011 | Hoover Vacuums
How can I repair the "Self-propelled" selector on a Hoover Windtunnel,Model U6445? Joe
Nov 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel vaccum U6445-900 motor not turning on. I removed the screws and located the contacts inside. There is an on-off switch which seems to be stuck Is there a way to replace this switch
May 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on windtunnel won't spin
Mar 21, 2009 | Vacuums
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover WindTunnel Self-Propelled V Belt
Hi, That is what was happening to my Windtunnel. Until I looked at the little round disk "plastic". there was a crack in it and this puts pressure onto that V belt to make the brush spin. I have a replacement idler arm assy unit which has to be replaced. I hope this helps Cindy G.
Aug 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
