My transcend storejet was working fine but there was a recycle folder which i deleted. Then when i try to access my harddisk, It says "windows cannot find G:\RECYCLER\0xBED095F.exe'.Make sure you typed your name correctly, and then try again.
  • 27,725 Answers
You could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Posted on May 29, 2011
  • Brian Sullivan
    Brian Sullivan May 29, 2011
    first check the recycle bin to see if the file is still there if this fails to fix the problem you might try to retrieve the file you deleted http://majorgeeks.com/FreeUndelete_d4407...
    FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
    Supported file systems:
    NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
    The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media.
Access Denied Error on external hardrive
You don't have rights to the folder. Right click the folder --> Select Properties --> Security --> Advanced --> Owner and then change the owner to your user. Here are some instructions from Microsoft for taking ownership. Once you own the folder then you can do whatever you want.
http://technet.microsoft.com/en-us/library/cc753659.aspx
Oct 21, 2012 | Transcend StoreJet Computers & Internet
I am having a external 250 Gb transcend store jet Harddisk..it was working fine but after 15 minutes....suddenly it is saying that write protected ,,,i am not able to copy anything to harddisk and not able...
I HAVE THESAME PROBLEM WITH Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive ON MY VISTA 7..WHY THERE ARE no any hints or answers here ? so we can get help? thanks
Jul 29, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
The properties of my hard disk (Transcend StoreJet 500GB) show that there are 465 GB space of the disk are used. So it seems that all my data is still on the disk. But every time when I am trying to start...
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
May 20, 2011 | Computers & Internet
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 20, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Unable to open Pendrive
Your pen drive is infected by a virus/worm. I have two solutions for this -   > If you have WinRAR software, just open up the pen drive using this and delete "autorun.inf" from it.  OR  > Use any good antivirus software and scan your pen drive, and disinfect the pen drive from any virus/worms. Remove your pen drive, and insert it again. It'll work fine.
Dec 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computers & Internet Logo
631 people viewed this question
David Payne
David Payne
