Question about Adtran NetVanta 1335 Router (1700515E2)
How do I configure a VPN on a Netvanta 1335 to be used with VPN Client Software?
  • 128 Answers
SOURCE: Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Posted on Feb 16, 2006
XBRMann
  • 38 Answers
SOURCE: Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Posted on Feb 09, 2008
  • 35 Answers
SOURCE: Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Posted on Aug 13, 2008
chessmaster2
  • 160 Answers
SOURCE: Configure VPN on Netgear WGT624
try here
http://search.techrepublic.com.com/search/netgear+router.html
Posted on Dec 02, 2008
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
Can you please advise how to do the password recovery on Adtran Netvanta 1335
Call ADTRAN Technical Support at 1-800-4ADTRAN and they will be happy to assist you.
Oct 08, 2010 | Adtran NetVanta 1335 Router (1700515E2)
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
I have an Adtran NetVanta 1335 Router that keeps shutting itself off everynight after my store does all it downloads. I have put it onto it own power supply, any assistance to help keep it up would be...
You need to enter maintenance mode (a web interface) and check the power settings from there as some of these have the ability to sleep etc at preset times.
sort of added security and green all in one function
Aug 31, 2010 | Adtran NetVanta 1335 Router (1700515E2)
Hello. It appears my router is blocking VPN access to the office server. I can connect using the ethernet cable so have isolated the problem to the router firewall. How do I get around this? Thanks
Hi
I will make a couple of assumptions on you setup. First, you have some type of highspeed internet. You have a retail type router/firewall plugged into your internet modem. You are using a VPN Client software installed on a PC or Laptop. By stating that when you connected using your Ethernet cable, you were plugged directly into the Internet modem.
Basically, what you have here is a configuration issue with your Router/Firewall. I use the Cisco VPN Client Software from home. This software uses UDP over TCP port 10000. Your VPN Client will use something along this line as well. So, you need to do one of two things here. Determine what Protocol and Port your VPN software uses. Login into you Router/Firewall and add that to your outbound allowed traffic. Or login into your Router/Firewall and configure it to allow all outbound traffic.
If you are not sure how to do this, the documentation that came with your Router should contain a Tech Support number to call. They can walk you through this in short order. Otherwise, post your EXACT make and model of your Router/Firewall and I will try to get the information for you.
Hope this helps.
Brian
Jun 30, 2010 | Linksys Computers & Internet
Can I establish a VPN Client Access with the motorola wr850g router. The ones at the college being used , routers that is, are Lynksys and are new ... AM in a rut here !!!!
you should but the question is: are you are authorized?
my understanding is that vpn connections usually required a client and you definitely need authorization configured on both ends.
attempt to configure the client in xp as explained here
consult with the adminstrator of your vpn lan site if there are any port forwarding that you may need to configure on your router.
good luck!
Mar 26, 2010 | Arris WR850G Router (DHWR850G)
How to configure the vpn client on vista for wireless router
i go to the windows media center
see dvd after 3 secend and click exit go to the task.com wait a
secend,, notify me when this question chances.
a vista can look after me........................ what are cofentable mean
vista can use ie8 in windows vista ultimate
Mar 10, 2009 | Microsoft Windows Vista Ultimate Edition
Vpn client
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Jan 15, 2009 | D-Link DI-804HV - 4-Port Broadband VPN...
Cisco VPN Client for 32 bit vista
Download the latest version of the Cisco VPN Client. My version is 5.0.03.0530.
You can also try using the Microsoft "MSIZap" utility to ensure a clean uninstall. It is a command-line utility. You will need the original MSI install file from the Cisco VPN client to use MSIZap.
You can download it here: http://msdn.microsoft.com/en-us/library/aa370523.aspx
Sep 22, 2008 | Microsoft Windows Vista Ultimate Edition
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Setting up a VPN through watchguard
The key with any VPN solution is to make sure that the configurations on both ends match. I am not very familiar with this particular product, but it looks like you need to have the proper VPN licenses installed first. There are two types of VPN you can do. 1) Site to Site - This is where the are two static boxes that you want to create an encrypted tunnel between 2) Remote User access - This is where mobile users connect to a central site over an encrypted tunnel from their home or on the road. Next, take a looks at the User Guide PDF here: https://www.watchguard.com/help/documentation/soho6.asp Chapter 10 tells how to configure the VPN on the Firebox side. You would just duplicate your settings if your doing option #1. Chapter 11 tells how to configure the VPN on the client side. This section would tell you how to configure the client software for option #2. Hope this helps.
Aug 29, 2006 | WatchGuard Technologies FireBox SOHO 6...
Adtran NetVanta 1335 Router (1700515E2) Logo
180 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
