Question about GE Profile PSS26NSTSS 25.5 Cu. Ft. Side-by-Side Refrigerator w/Integrated Dispenser & Custom Cool Te...
Freezer and refridgerator are both not cooling. LIght goes on when door is open. I was working fine last night but water on the floor this morning alerted renter to the problem
    President:
  • 2,468 Answers
The ptc overload on the compressor needs replacing by unplugging it off the compressor and getting an exact replacement
Posted on May 29, 2011
KFCS22EVMS leaked once made noise
Watch to see if 1) the water dispenser freezes 2) if you end up with ice build up. What you might have heard was a heater element pop. If that is what happened, then the cooling coils will freeze, no air will flow through the coils, and the freezer will not get very cold. If you can find a diagram of your unit, it may be worth taking a look to determine if the heater element is ok and/or if the cooling coils are packed with ice.
Oct 18, 2012 | Refrigerators
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Oil and water on floor near upright freezer
Possible you have a sealed system problem, although you state it is working now. Maybe an overflow from drain pan is why there is water again.
Apr 26, 2009 | Kenmore Freezers
Whirlpool Refrigerator/Freezer not cooling
Unplug from wall and let unit subside 1 hour. then plug back in and check operation. Was unit tilted or moved prior??
Please rate. Thank you. jj505
Mar 28, 2009 | Jason Natural Cosmetics Jason Forma...
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
Freezer not working - GSS20IGPA WW
All cooling starts in the freezer section where the evaporator is. Too much stuff in the freezer can inhibit the necessary airflow around the evaporator and cause it to freeze. Usually, the next defrost cycle will thaw it, but it can keep the cool from coming out. There are so many things that can cause the lack of cooling, but most often, it is NOT the compressor. e.g. - if there's water pooling on the inside at the bottom, you have a bad door seal. If no real cool ever happens and you don't hear the hum of the compressor often, you defrost timer is bad.
Jun 09, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Profile PSS26NSTSS 25.5 Cu. Ft. Side-by-Side Refrigerator w/Integrated Dispenser & Custom Cool Te... Logo
134 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
