Question about Olympus Camedia C-4000 Zoom Digital Camera
Yep. another lens stuck.
Hey. i've had my 770SW for a while now. today at the beach. the lens became stuck open. it appears to be loose, with a bump on either corner the lens can be knocked a couple of mm from the fully extracted position.. when turned on i can view my photos but i receive a black screen if i try to take a photo. an audible noise is heard from the lens trying to retract. is this a problem i can fix myself?  My Olympus C-4000 is stuck open. The lens will not retract when turned off, and it will not take pictures when on. It makes clicking noises and then a beep -beep-beep with the green light flashing on and off a few times. Then silence and nothing.
Re 770sw shutter problem:
Had our camera for over a year now, and travelling through South America we´ve had our little camera up on mountains over 6000m in freezing conditions and down to the depths as well as dropping it numerous times. It has been great. That is until the lense (calling the metalic thing that opens and shuts the lense, wrong but sue me!) would not open or shut properly. This problem would prevent us from taking any further pictures. When power was pressed the lense would close, screen would go black the lense would open and then half close again and screen would turn off again. After thumping it a few times the lense retracted completely, seemed to be slightly loose and the camera would still not work. When pressing the on button the camera would make little clicking sounds like it was trying to open and close but nothing. All this time we could still see pictures we had previously taken but of course take no more.
OK long winded but if this sounds like you this is how we fixed the problem.
First took off the front plate. Easy to do with an allen key (one of ours didn´t come off so we just bent the plate up) There is only one screw that holds the lense in place and also another little piece of metal that on our camera seemed all bent up. We removed the screw and straightened the little piece of metal as best we could. On this little piece there was a small hole which seemed to coincide with a raised little plastic ***** on the camera, maybe thinking these need to be aligned to have the camera work, maybe not. Screwed the lense back on with the other little piece of metal all straightened and made sure it would all align when the lense was open (meaning that the little hole in the small bit of metal would meet up with that little ***** of plastic when the lense was open,,,clear as mud???)
Face plate returned but would still not work. At this stage actually started looking at new cameras. One last attmpt i pressed and held the menu button when the camera was turned off. The lense shut. I pressed the power button and it has worked great ever since. Knock on wood.
So to be honest i´m not what exactly i did i just know i had one of these similar problems and my camera is now fixed.
Really hope this helps as apart from this our camera has been fantastic.
Cheers.
Posted on Oct 28, 2008
  • benoverseas Oct 28, 2008
    m.o.u.n.d (the computer has decided to replace that word with stars(
    LOL
    Problem Solver:
  • 9 Answers
It depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Posted on Aug 20, 2008
My 2007 mitsabishi triton A/T gear shift is stuck in drive.I believe it could be a solenoid.It happened after driving on the beach. Cheers
Are you sure it's not just the linkage jammed up with sand? If it is internal, drop the pan and you should be able to see if a solenoid has broken, as they usually come loose from the base. Good time to change filter and fluid too.
Jan 15, 2015 | Cars & Trucks
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My lens for my ixus 750 is stuck open. when
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The lens cover on my olympus stylus 770sw is stuck open and the camera will not turn on.
I have a u770 with a broken lens. I would like to either buy yours to repair mine or I am willing to sell mine so you can repair yours. Email at (g4)(kpp)@(hotmail).(com) - remove the brackets - trying to avoid spam
Oct 17, 2009 | Olympus Stylus 770 SW Digital Camera
770SW Olympus needs a factory reset, lens stuck open
Contact Olympus for the factory reset code.
Sep 01, 2017 | Cameras
Canon PowerShot A720IS Lens Cover Won't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A720 is more complex, but the base procedures are similar:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 28, 2009 | Canon PowerShot A720 IS Digital Camera
NIKON L15 LENS ERROR
Lens errors, must be fixed by a camera repair shop. They are usually caused by impact of the lens with an object or sand from a beach. Repair estimates range from $50 to $100. Get a new camera if it is closer to $100. Suggest a internal zoom lens like the Fuji Z10fd.
Mar 19, 2008 | Nikon Coolpix P1 Digital Camera
i had this problem after putting it in a jug of bear (i know, i know...not so smart)...i washed the camera with a small amount of dishwashing detergent and a good rinse and it seemed to solve the problem for me....not sure if this is the recommended way of dealing with it though.
Oct 22, 2007 | Olympus Stylus 770 SW Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lens cover is stuck
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Sep 07, 2006 | Canon PowerShot S45 Digital Camera
Olympus Camedia C-4000 Zoom Digital Camera Logo
205 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
