Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My dls 3500 mower will not start at all, I charged the battery but the engine wont even turn. All the wiring and fuses seem to be ok
I had the same problem. I replaced the wiring harness for a short fix, corrosion in the terminals that connect to ignition switch. This worked for a while. Then replaced ignition switch this also worked for short time. Now I just open the hood to reach behind the ignition switch and wiggle wires while turning key to start until it starts keep wiggling to get good contact. If it won't stop after it starts, wiggle wires after you turn the key to off. It will stop.
Posted on May 29, 2011
Pontiac Bonneville Wont start and charge after i changed alternator
Check the wire from alternator to fuse box for a bad wire or a break in it. or corrosion on it. Battery cables loose or corroded. Is the battery ok!! check the main fuses in under hood fuse box. Good-Day! The charging wire goes to the fuse box first.
Mar 03, 2015 | 2001 Pontiac Bonneville
Why wont it start
is the the battery 100% charged? and are the fuses good?also check ground wires.
Oct 04, 2014 | Poulan Garden
Why wont my scotts model #1642h charge the battery?
mice like to eat the wires under the engine cover check there next
Jun 25, 2012 | Garden
Craftsman DLS 3500 sounds like engine is knocking. What should I do?
stop running it till you find out before it cant be repaired check the pulley bolt on the bottom check the valves then take it apart
May 26, 2012 | Garden
I put one of the cheap Wal mart batteries in my riding mower in the spring. The last couple times I used the mower I had to charge the battery for an hour or two before starting. Tonight when I turned the...
things to check first: make sure the battery connections are clean and tight; check the ground at the frame; check the fuse. you didn't mention brand of engine but, the starter gear may be stuck in the flywheel or the valves need adjusting, and the start solenoid could be defective. BUT, since the battery seems to need charging all the time, on a briggs, the diode in the alternator wire could be shorted, allowing the juice to flow back out of the battery - kohler and kawasaki usually use a voltage regulator that could be shorted
Aug 18, 2009 | John Deere Garden
Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
May 20, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
New battery won't take charge
Hello, and how are you. It could possibly be the charger itself If everything else seems fine. If all wire connections at the starter and the battery are tight, clean and no cuts any where on the wires them selves.I would try a new charger. Another thing is you could see if someone could check the wires with a meter to see if there are any unnoticeable breaks in the wires.
Jan 09, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
574 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
