Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
I have a Yard Machines by MTD, 638 RL, Model 13A1762F, 13.5 HP, Tecumseh engine. Yesterday, after using it without incident, it died while putting it away. The engine turns over, there is fresh gas in the tank. The spark plug fires and a shot of starting fluid in the carb does nothing. Any ideas?
  • Alan Childers May 29, 2011
    Just checked the flywheel key. It is good. (was sorely hoping that was the problem)
    Anyone else have any suggestions? My Yard Machines 638 RL will not start. Engine turns over, spark plug fires, fresh gas and flow to carb is good, starting fluid in the carb has no effect, timing key is intact.
    Could it be a safety switch somewhere keeping the engine from starting?
Recently had same problem with this machine with a Tecumseh 17.5hp. There is a solenoid on the bottom of the fuel bowl that controls fuel flow inside the carb. It is controlled by the ignition switch. Mine got stuck in the closed position. I could not find a replacement, so a small engine mechanic told me I could disable this by removing the solenoid and cutting off the pin. This worked for me. Then, for safety, put a fuel cutoff valve in the fuel line.
Hope this helps.
Hank in Marietta, GA
Posted on Sep 19, 2015
    Sergeant:
  • 189 Answers
Sounds like you need the carb cleaned. This can be a pretty tedious job. It's easier with small engines but still risky. If you have a lot of mechanical experience I would go for it, but if not you should take it into a repair shop. http://www.bensalemlawn.com
Posted on Dec 06, 2014
There might be something wrong with the engine. While your lawn care equipment is different from my car, my car was doing something similar a few months ago. I can't remember what exactly was wrong with it, but I can recommend having a professional mechanic look at it. We can't be as much help since we can't look at the engine.
Claudia Rosenburg '
http://www.pbequip.com/
Posted on Jul 17, 2014
  • 1,179 Answers
Air is not getting into the engine, clean the air filter. Or it may be due to a fuel blockage in the pipe. I would clean the air filter and the carberator.
First try just the air filter, you may just get away with it ey! Won't be too much work.
Take care!
damnor01
Posted on May 29, 2011
    President:
  • 2,468 Answers
Did it possibly shear the flywheel key?which would throw it out of time,remove the top cover and see if the key is sheared off by removing the flywheel
  • danny Hendrickson May 29, 2011
    also what color is the spark ? blue or dull orange?and is it a large healthy spark at the spark plug?,possible the ignition module is getting weak or its ground is bad due to a rusty high resistance connection, check this also as grounds are important in ignition systems too or the flywheel is just rusty enough to limit the pick-up modules signal,check the flywheel for rust also,and kill or distort the spark impulse signal too
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
I have Yard Machine 638 RL, Model 0V358EA, 13,5 hp. I want to change the Oil engine how many litter must put oil in the engine
The Tecumseh OV358EA 13.5hp takes one quart of oil, 32oz or 39oz with filter. Use 30W except if it is used in very cold climates. MTD makes a drain tool for around $5 that clips onto the drain plug area and allows you to direct the draining oil into a container with a lot less mess.
tom
Apr 26, 2012 | Mtd Garden
What kind of oil shoukd I use on a 24"cut MTD yard
I'm assuming you have a Tecumseh engine on there. But a Briggs would be the same. This is straight from Tecumseh, though (long story short is run 5W30 Oil or 0W30 Synthetic in it assuming winter temperatures:
Oct 26, 2011 | Mtd 22" Yard Machine Push Mower
Looking for tecumseh ohv 175 manual for yard machine mower
The MTD Yard Machines site requires the model number AND serial number submitted to download any of their manuals. Here is the link:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10201#
Nov 16, 2010 | Mtd Garden
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
I have an old hssk50-67244 with the extended cam shaft(pto).. Can I buy a new Lh195sa engine and swap cams and cover
Yes. But horizontal crank PTO engines were in production untill Tecumseh died at the end of 2008, so you should be able to find the right engine.
If you go the 'donor engine' route, replace the lifters as well. It will sound like a bag of nails after 50 hours if you don't.
Feb 20, 2010 | Mtd Products Yard Machines 158CC Tiller
Looking for a carburetor for a yard machines mtd
You may have better luck in identifying the engine type and manufacture (Briggs & Stratton, Tecumseh, etc) and get the number of the engine vs the machine itself, if possible. If you are able to do this, you can search ebay or the net for a wider range of possibilities for a purchase.
Feb 19, 2010 | Measuring Tools & Sensors
I have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
These engines do not have an idle mixture adjustment. Most of the problems with them not running right are from bad gas, water in fuel, or carburetor jet deposits. If your fuel is ok, then you'll want to clean the carburetor metering hole. You'll want to either empty the fuel, or clamp the fuel line, but after that, take the nut off the bottom of the carburetor bowl. You will see holes both in the sides, and through the middle. Use a wire to clean these out, and some acetone or carburetor cleaner to get the rest of the deposits out, and you should be fine.
Apr 14, 2009 | Mtd Products Yard Machines 158CC Tiller
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
2,118 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
