The printer has just been serviced, had the heads cleaned and now the printer is offline and wont print
  • 73 Answers
Right click to printer then go to OPEN>PRINTER> uncheck the use printer offline.
Posted on May 29, 2011
HP 1200 Business Inkjet, dutifully prints BLANK info page from printer button.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 19, 2013 | HP Inkjet 1200dn Printer
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
Apr 17, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Yelllow wont print,...changed cartage cleaned
If after cleaning the print head and changing the cartridge yellow still doesn't print, it sounds like there may be a problem with the print head or the board that controls the print head. The print head may not be receiving the signal to turn on. Check the circuit boards on the machine for obvious damage or a burn smell. Depending on the model printer it may be cheaper to replace the printer than to have the board or print head replaced.
May 15, 2010 | Epson Stylus 2200 InkJet Photo Printer
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not copying
Epson printers are known for clogged print heads.. its their piezo technology! sucks! you verified that your inks are full? if so its the print heads run the maintenance cleaning if still wont print needs to be service by someone like my self of print head replacement
Mar 31, 2010 | Epson Stylus DX6050 All-In-One InkJet...
I have problem with print-head for PGBK-5. On the test-print it does not appear as the pattern suppose to be (from the top) PGBK, C, C, M, M, Y, and BK. The pattern always appear C,C,M,M,Y and BK. I used...
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too. this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech. head cleaning and servicing will solve the issue
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Had not used it for a while.. put in new ink..even after several cleanings..it wont even print out a thing
Head cleaning is mechanical proccess, printing is electrical proccess. If nothing at all ink out/spray from head in printing proccess, problem with electricity. Damage board or short circuit at head cable. Check board first, may be some component "burn".Better to take printer to epson service center. Damage board can be replaced, but it must to check the cable head and small circuit at head first.
Aug 17, 2009 | Epson Stylus C84 InkJet Printer
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
No printout showing (offline)
If printer wasn't used much before you got it I would suggest that the heads are blocked. My experience with Canon Smartbase printers is they block easily. Try to soak the head in warm water or use an ultrasonic bath to clean out the head and see what happens.
Oct 20, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
k24674
