Sungale DVD-2026 DVD Player Logo
Posted on May 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Displays no disc - Sungale DVD-2026 DVD Player
  • debracarneyc May 29, 2011
    brand new display says no disc have changed all codes to 255 and 3000 and 4000
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on May 29, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
13123
Points
286
1.) If your display is no disk it's possible that your disk you inserted is corrupted or dusty, try to clean your disk with wet clean cotton.
2.) If does not work it is also possible that the CD is only a pirated, try to insert original CD and play it.
3.) If does not work again, try to remove the cover of your DVD and checked all the connections of the DVD connector from the circuit board, try to reconnect the connector and tightening it.
4.) Common problem from the DVD player is the sensor from the DVD reader checked if it is dusty or not, tries also to clean it with clean cotton.
5.) And if you try all of these method and your DVD still doesn't play again, it possible that the sensor from the DVD reader is defective try to replace the sensor with the help of technician.
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
1helpful
No dics display
That means it can not focus on the disc or that you are using the wrong disc type like a DVD in a CD player. Try cleaning the lens.
1helpful
Get display : NO DISC or BAD DISC
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
Sep 30, 2009 • GPX PDL705
1helpful
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
3helpful
SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
MDS E12 displays 'Over' and ejects all discs with 'Read Error'
"Over" is always lit in the display. It just marks the end of the VU meter scale.
You have a drive problem. Nothing to do with your track 15 operation.
I would suggest reseating the drive ribbon cables, oxidation of these is a common theme with my MDS-JE530 which shows the same symptoms periodically.
Top Sungale Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
