Question about Kenmore Microwave Ovens
Kenmore Microwave Oven; model No 721.62463200 - is not working. When we turn it on it appears to be operating normally (Light on, fan on, turn-table spins), but nothing heats up. The clock only shows " : " when not in use.
  • Patrick May 29, 2011
    Daniel,
    Is the door switch easy to repair by myself? I'm looking at the KENMORE parts webpage and have no idea which switch I would replace
  • Patrick Jun 12, 2011
    The parts finally came in and I replaced both switches. I still have the same problem, the power appears to come on: the light, fan and turn-table all work, but nothing heats up. Any other suggestions?
    PS thanks for the video and parts break-out
  • 4,323 Answers
Hi
If everything else is working fine then it seems the issue is with the door switch, if this switch is bad control senses that the door is still open and so won't heat. Hope this helps...please post back for further assistance.
Daniel
Posted on May 29, 2011
  • Daniel Scott
    Daniel Scott May 29, 2011
    It's easy to replace, just need to disassemble the front panel. Please check part#4002 in this link---
    Please check this video it'll help---
    Daniel
  • Daniel Scott
    Daniel Scott Jun 12, 2011
    Then the issue is with the magnetron or the high voltage transformer that is bad and should be replaced.
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Microwave turntable.
Is that the only thing that doesn't work? If so it could be a coupler or a belt, possibly the motor it self.
Sep 17, 2009 | Kenmore 63252 Microwave Oven
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Maytag microwwave oven
check the magnitron and capacitors one of this bad
Sep 18, 2007 | Kenmore 80412 Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
339 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
