Question about Dishwashers
I need to download a wiring diagram for a maidaid c40 glasswasher. Not available from Maidaid. Basically, need to confirm that timer contacts 111.....112, provide the interlock connection that keeps timer running after start impulse switch is pressed. If correct, I need to order a new timer. Best to send me a wiring diagram really. Can you do that...............thanks.
  • 5 Answers
SOURCE: need wiring diagram for a
You're in luck - I've just had one apart to repair the wiring loom.
The door switch is a simple two-pole latching switch with the wiring as follows.
This is the order of connections from the front.
1. Brown - Live (fed from mains)
2. Red - Load (goes to controller)
3. Black - Load Neutral (return from controller)
4. Blue - Neutral (goes back to mains)
By the way - the flat wiring loom gets fatigued at the bend at the bottom of the door and will eventually short out. Easy to fix with heatproof cable stripped out from an immersion lead.
Posted on Sep 23, 2008
  • 1314 Answers
SOURCE: Door interlock switch
the door interlock switches are safety switches so the washers stops when the door is open if bypassed and the door is open could be a mess and damage floor so let your mind be your guide its not recommend by factories who are damage minded hope this helps but it wold work i mean if such a condition existed the washer would run
Posted on Jan 11, 2008
  • 1462 Answers
SOURCE: Door interlock appears faulty on
only solution is to replace the interlock - it is just held in by 2 screws
Posted on Nov 26, 2008
chuck943
  • 783 Answers
SOURCE: 2000 expedition multi-function switch connector wiring diagram
Is this the one?
Posted on Apr 14, 2009
gotgeek2
  • 565 Answers
SOURCE: Need wiring diagram for Intermatic 240V Mechanical Time Switch
For anyone else who may be reading this post, these instructions are for the T104 ONLY.
Connect your incoming line) 240 volt wires to terminals #1 and 3. Connect the outgoing 240 volt (load) wires to terminals # 2 and 4. Don't forget to connect both equipment ground wires (bare or green) to the "GR" terminal.
Do NOT connect anything to the "A" terminal.
Posted on May 09, 2009
Maidaid dishwasher is in safe mode how do I change this
it may vary depending on the model number. if you google "maidaid dishwasher xxxx manual" where xxxx is your model number you can find the manual that should tell you how to fix that issue.
Apr 01, 2016 | Computers & Internet
No resistance. Already replaced alternator and resistor. I did the B+ and field wire test, and I get resistance that way. Also, the console flashes a 1 across the screen, that does not go away. Thoughts?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have done the proper test to rule out the alternator as the culprit. Not knowing which console you have on your unit, it sounds like the console is the problem. If you have the C40 type console, you can replace the PCB and PCBa to correct this issue. If you have the older style console, with red leds instead of white, you will need to find someone that can rebuild the console board. The board is no longer available in the older consoles. The following links will take you to the PCB and PCBa needed for the C40 console.
PCB for C40 Console SM27130 SPORTSMITH net
PCBA with LCD Screen for C40 Console SM40070 001 SPORTSMITH net
Oct 06, 2015 | Exercise & Fitness
Need to know simple wiring where power output pins are on eagle signal control off-delay timer #81Q2A605
1) Copy following link for general pin timer wiring:
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) Eagle tech support:
http://www.danaherspecialtyproducts.com/Eagle_Signal/Service_and_Support/Customer_Service___Tech_Support/
3) Fixya appears on 1st page of google search for this product, indicates there is no clear information available on the web.
4) Add a comment and describe the wiring diagram that appears on side of device.
Each pin timer has wiring diagram.
The image I found shows 11-pin base, and push button or impulse input connects to terminals 2 and 6. Image is not clear enough to determine more information.
Feb 20, 2013 | Hardware & Accessories
Norris e17 glasswasher doesnt stop after cold cycle
Possible that the program controller timer is not contacting to the cycle so as to proceed. You need to use a multimeter and check the voltage to the next cycle, Also if you can observe the movement of the timer - the stepper motor , it will be easy to know if the timer moves to the next contact so as to switch on the heater.
Replacement is the best option if this is confirmed but make sure to tag all the connections...
Jun 30, 2012 | Washing Machines
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Nelson speedwash glasswasher instruction manual/wiring diagram to work out controls etc.
Nelson SC40A-11 long time to fill & drain, uses a lot of detergent
Jan 25, 2011 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
