Question about Belling Microwave Ovens
Fitting intructions for cooker hood uih60s - Belling Microwave Ovens
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Hi, I have a hotpoint cooker hood and the lights keep fading out then flashing on again.
Sounds like loose/burned wiring at the plug or spur unit .Check mains feed
Feb 22, 2011 | Hotpoint Microwave Ovens
I have a plaster board wall,can i fit a cooker hood to this
Yes but only if you fix into the wooden stub work behind the plasterboard.
Feb 14, 2011 | Microwave Ovens
How do i fix a LOGIK L90CHDG10 90cm Cooker Hood to the wall and what are the power requirements thanx
That should come with a drawing to cut out, sometimes the box itself will have that on, and one places it on the wall to mark screw holes for fixing.
It will run, as it is only a fan and a light buld, from the cooker switched outlet on the cooker point, or a fused outlet from a spur.
If you are unsure, get a qualified electrician to wire it in for you!
Jan 15, 2011 | Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Jan 01, 2011 | Microwave Ovens
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
