Question about Toro Garden
I have a toro model 51974 gas trimmer, i got it started, it ran for 20 minutes and stalled, now I can not get it to restart and run
  • Toro Master
  • 7,482 Answers
Hi zoe575...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Gas leak where gas lines enter and leave tank
Also, make sure that the vent for the fuel tank is working. the vent is either on the fuel cap itself or thru a device commonly known as a duck bill valve, so named because of the shape of the valve. All the vent does is allow a slight amount of air to enter the tank while the trimmer is running.
Loss of power
Loss of Power could be
a. Restricted Fuel Flow through the CARB
b. Plugged or Fouling Spark Plug
c. Worn Piston Ring..
ALWAYS make sure you use a High Quality 2-Stroke Oil...
Apr 08, 2013 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
How to load string into trimmer head
pull head off cut 1 piece of line bout 48 inches should be a **** in center of head put center of line in slot then roll line in same direction in both slots lock ends in head reinstall
Jul 15, 2012 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
Engine Stalls out
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Poulan Pe550 Gas Edger
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
555 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
