Question about Eagle CUDA 350 S/Map
Unit locks up when powered on. Will not move past the first screen. All troubleshooting in the manual has been performed.
Lowrance troubleshooting
Pay attention if depth readings shift during times when moving from spot to spot at higher speeds. If this is the case then you have air bubbles disrupting your sonar signal causing inaccurate readings or a loss of bottom lock for the unit. If over this weeds in shallow water, this at times creates havoc with sonar readings because of the wide variance of signal returns.
check the voltage at the head unit.You should have a minimum of 11.7 volts. 12.5 to 13.5 is optimal
lower power input can affect the overall performance of your unit.
Sep 04, 2014 | Lowrance Boating
Acer Iconia Tablet A500 won't boot past the Acer logo screen
How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Mar 06, 2014 | Acer Iconia Tab A50010S32u Notebook
Some how my screen not coming on. The power is coming to the switch but screen not coming on
Without knowing the make and model, I can offer only general troubleshooting tips.
First off, when the machine is powered on, does the CAPS lock light work? If not, 99% of the time it is not getting past POST (Power on Self Test) and is hardware not initializing correctly, or failed. If this is the case, removed battery, unplug power, and hold power key down for 30 sec to discharge any power in the notebook. Connect battery, plug in, try again.
If the CAPS lock light works, tilt the screen towards a light source (will have to move around quite a bit) and look for a faint image on screen, if you see a faint image, the screens back light is not working, which could be many things (bad connection, inverter for CCFL lamps, bad voltage regulator for LED back lights, etc).
If you feel comfortable, you can try reseating memory, hard drive, wireless card, etc. essentially all the easy to get to components. You can also try deducing it, but removing one at a time...
Hope this helps steer you in the right direction
Good Luck!
Dec 06, 2013 | Computers & Internet
Hc 21 camcorder touchscreen problem
Please follow the troubleshooting steps provided below and check the operation:
1. Rotate the screen and check if that helps.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
Jul 04, 2012 | Sony Video Cameras
Screen goes black shortly after turning on
I'm sorry that the screen goes black shortly after turning on the camcorder. I suggest that you perform a manual power reset and check the operation. Follow the steps to perform a manual power reset:
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-SR42 Camcorder
My Sony Vaio Is Not Starting Up
Hi aleena_khan.
Based on the information you have provided, the issue might be due to the Battery or the Power settings.
As the issue might be due to the Power Unit in the Notebook, this might also be related to the Hardware problem(Power Unit).
Hence, it would be better to get the Unit examined at the authorized Service Center.
However, you may first try performing the troubleshooting steps which I have mentioned below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C390934&fes=true&mdl=PCGK33P
The above link has all the possible troubleshooting steps.
Hence, please try performing all the troubleshooting steps mentioned on the page.
Performing the steps should resolve the issue.
If the issue still persists even after performing all the troubleshooting steps, the issue might be Hardware related.
Hope this helps.
Please feel free to contact for further information and assistance.
Aug 31, 2010 | Sony VAIO GRX550 Notebook
My sony Vaio PCG 272L will not power up. The cord is good as it powers up my moms Sony. The monitor on/off lits up when I press it. Any idea what the problem could be?
Hi chris_rovie3.
Hope this helps.
Aug 24, 2010 | Sony VAIO PCG-K33P Notebook
Lexmark all in one x5100 series begins to print then stops with"hardware error message 0502
This is copied out of Lexmark's KnowledgeBase, just so you know I'm not coming up with this off of the top of my head. Go to www.lexmark.com and click Support > Technical Support, and then search for ID: ENUS22800 if you would like to see the original, complete with pictures. Or, here's a text version:
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
The steps below will help you to identify and resolve each of these four issues.
1. Turn the printer off and disconnect the power cable from the back of the unit.
2. Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3. Remove both of the cartridges.
4. Move the cartridge carrier over to the left-hand side of the printer using the carrier belt.
5. Gently clean the encoder strip with the cloth.
6. Move the cartridge carrier back to the right-hand side of the printer using the carrier belt.
7. Reconnect the power supply and turn the printer back on.
8. Perform the printer hardware test. Instructions on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9. Power the printer back off and disconnect the power cable from the back of the unit.
10. Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11. Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer.
12. Reconnect the power supply and turn the printer back on.
13. Perform the printer hardware test.
Reseating the encoder strip:
1. Turn off the printer and disconnect the power cable from the back of the unit.
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently pushthe encoder strip down and then back up to get it into the slot. Ifthe strip is completely out of the slot, it may be necessary to moveit first forwards and then back.
4. Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5. Reconnect the power supply and turn the printer back on.
6. Perform the printer hardware test. Click here for instructions.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps:
3. Remove the black/photo cartridge.
4. Move the cartridge carrier back to the left-hand side of the printer using the carrier belt.
6. Perform the printer test. Details on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
Contact Lexmark if the problem persists with a new cartridge.
Color cartridge troubleshooting steps:
3. Remove the color cartridge.
6. Perform the printer hardware test. Instructions on how to do this are here:
If yes, repeat steps 1-7 with a new color cartridge.
If no, contact Lexmark.
Hope this helps!
Jan 21, 2009 | Office Equipment & Supplies
Cartrage stop moving and all power ,copy ,scan and fax buttons are lightening
It might be a hardware issue however u can try the following basic troubleshooting steps .
Unplug the power cord from the back of the unit . try to move teh carriage manually .
perform a reset as well .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6
Thanks
May 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Error #0502
pattlnk_4242006_196-lable.jpg Legend:A: Encoder Strip (semi-transparent grey strip)
B: Carrier Belt (black and brown toothed belt)
C: Cartridge Carrier
Troubleshooting Steps
WARNING! Be very careful when cleaning or adjusting the printer's encoder strip.
Required materials
You will need a dry, soft cloth
Embedded links in the table will take you to specific troubleshooting steps.
Step Action 1 Turn the printer off and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 Remove both of the cartridges. 4 Move the cartridge carrier over to the left-hand side of the printer using the carrier belt. 5 Gently clean the encoder strip with the cloth. 6 Move the cartridge carrier back to the right-hand side of the printer using the carrier belt. 7 Reconnect the power supply and turn the printer back on. 8 Perform the printer hardware test. Click here for instructions.
9 Power the printer back off and disconnect the power cable from the back of the unit. 10 Open the printer's front cover.
11 Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer. 12 Reconnect the power supply and turn the printer back on. 13 Perform the printer hardware test.
Embedded links in the table lead to specific troubleshooting steps.
Step Action 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and then back up to get it into the slot. If the strip is completely out of the slot, it may be necessary to move it first forwards and then back.
pattlnk_4272006_149-reseatenc.gif 4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test.
Black/Photo cartridge troubleshooting steps Embedded links in the table will take you to specific troubleshooting steps.
pattlnk_4242006_1911-beltmove.jpg 3 Remove the black/photo cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer test.
If you attempt the steps with a new black/photo cartridge and the error persists, proceed to Contacting Lexmark.
Color cartridge troubleshooting steps Embedded links lead to specific troubleshooting steps
pattlnk_4242006_1911-beltmove.jpg 3 Remove the color cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test. Click here for instructions.
If no, proceed to Contacting Lexmark.
If you have attempted the steps with a new color cartridge and the error persists, proceed to Contacting Lexmark.
Feb 21, 2008 | Office Equipment & Supplies
Eagle CUDA 350 S/Map Logo
26 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
