Question about Denon AVR-1709 Receiver
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the maximum and have no sound on Front Right. Thanks.
  • 4,234 Answers
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
Posted on May 29, 2011
How do i get all 5 speakers to work? only the three front ones work not two in back
Check the source, is it a surround sound source? If not, you'll need to change it to a 5/7 channel stereo setting, probably under the music option. Most music is only stereo, because we only have two ears!
Jan 27, 2015 | Denon AVR-E400 - 7.1 Network Home Theater...
Hi, I am using the AVR1612 with an MP3 player. The center speaker and the suround speakers do not work. When I test the speakers they are all working fine. The cables are plugged correctly
Your mp3 player only supports 2-channel stereo. To get sound from more speakers, you need to select a sound program, try selecting one of the sound field options on the bottom right of your remote (music cinema, direct, ... ).
Jul 24, 2011 | Audio Players & Recorders
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Jan 07, 2011 | Denon AVR-1709 Receiver
The Graphic Equalizer pattern control is not working correctly - I can hardly hear the vocal on my CD's when playing even though I've selected vocal. Vocals are outplayed by background music.
That sounds more like a polarity, or phase problem. Make sure your speakers are hooked up correctly, with the correct colors going to (+) positive, and (-) negative. Make sure your rca connection are correct, and that every connection has a left and a right. No stereo-to-mono adapters.
Is setting to "vocal" an eq selection, or a "dolby" stereo selection?
Are you using a dolby surround stereo receiver with left, right, center, rear, etc.?? If so, try turning off any effects, or anything that would send signal to the center speaker.
Lastly, depending on what the source of your music is, it is possible if your connections or receiver settings are not correct...that the music upon playback will be out of polarity, meaning the vocal portion will cancel out. Combining left and right signal together can sometimes do this as well.
Apr 09, 2010 | Denon D-C30 Shelf System
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
Not getting Audio from the Front B Speakers
There are two ways to get change the speaker config that I didn't see at first. One is the curved-line 'Speaker Menu Guide') button on the front of the remote below the wheel that toggles A, B, A+B. The other factor is to choose a Surround Parameter that doesn't send all the audio through the center channel - (keep pressing SIMU button on the back of the remote to cycle through some DSP profiles, I'm using the 5Ch Stereo).
Dec 07, 2008 | Denon AVR988
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
No sourround sound
read your manual well and double check all your connections,make sure the remote is working, check the battery contacts in it too. If you haven't got a manual, obtain one.
Sep 29, 2008 | Denon AVR-1706 Receiver
Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Jan 18, 2008 | Denon AVR-1804 Receiver
Denon AVR-1709 Receiver Logo
171 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
