Question about Epson Stylus C86 InkJet Printer
I put new ink cartridges in and now it doesn't print anything.
  • 4,234 Answers
This may sound silly, but I have done this as well. New ink cartridges are shipped with "covers" that should be removed prior to installation. Please verify that these plastic covers have been removed. This is the most common cause of this problem. The covers look like transparent tape.
Update this with the results of your examination.
Thanks,
Dan
Posted on May 29, 2011
My printer display says cartridges appear to be missing or damaged
Either the cartridge is malfunctioning, if you used refilled cartridges this common, or they came unseated. Check to make sure they are seated correctly by removing them and putting them back. If that doesn't work try replacing them with new, not refilled, cartridges and see if that resolves the issue. If it doesn't the problem is a circuit problem that will need to be repaired by a technician.
Oct 26, 2011 | HP Officejet 6500 Wireless All-in-One...
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
The printer marks an error with the color cartridge, i open it check it and still has ink, but still doesnt wanna print, what can i do? Its a lexmark x 2695
It could be that the color cartridge has gone bad now. Try to re-seat the color cartridge in the printer. And if that doesn't help, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Sep 11, 2011 | Lexmark X2600 InkJet Printer
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have an HP Photosmart 2575 all-in-one printer, and my black is not working I just replaced it with a new cartridge and it still doesn't print the black.
The new ink-cartridge probably is OK.
So, start the HP Printing Assistant Software, and run the "Print-Head-Cleaning" utility, to run a few cycles. Hopefully, it will unclog the ink-jets that _should_ be spraying ink onto the paper.
Jul 25, 2011 | HP Office Equipment & Supplies
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the...
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus C86 InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
