Question about NAD C355BEE Amplifier
My C355Bee amplifier will not switch on. The power light stays on orange and won't switch to green.
  • 4,234 Answers
This is usually called "protect mode". See the link below for an explanation. If the unit remains in this condition even after disconnecting all speaker wires, it likely will require service. Please update this if you need further information.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on May 29, 2011
Schematic diagram
check the pcb mounted fuses on the power supply board They look like resistors only they have 1 colored stripe. replace the open (resistance above 1 ohm) fuse and enjoy your amp.
Jan 04, 2014 | NAD C355BEE Amplifier
Nad c355bee
Check to see if it works with headphones. If it doesn't then you might have a main power amp failure.
Aug 06, 2013 | Audio Players & Recorders
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Mecer LV26 LCD monitor won't switch on
This is an indication of protection error and might require attention of a qualified service technician. Before that, look for any loose contacts in RC jack, cables, power outlet etc. Try changing the input device to some other that works.
Aug 11, 2012 | Televison & Video
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
C355Bee and C162 Problems
Get your money back. I had similar problems with new NAD purchases a year or so back. NAD has had all sorts of repair issues.
I'll never buy anything from them again.
Aug 24, 2008 | NAD C162 Amplifier
1993 ford taurus
Would you be aware if there is a pre-installed external amplifier attached to the old head unit?
If yes, the speakers are connected to the amp and not to the new CD player. There should be a pair of shielded wire with RCA male connectors that should go to the head unit and the other ends would be attached to the amplifier. Additionally, there is a trigger wire from the head unit that switches the power of the amplifier to ON aside from the power B+12 and GND.
If no, on the Ford pls verify that:
Green/Yellow - always on B+12VDC (positive battery terminal)
Yellow/Black - switchable +12 (ACC terminal of your IGN switch)
Black/Light Green - chassis ground
Orange/Blue - remote trigger on for power antenna or external amplifier(s)
Light Blue/Red - park light
Speakers
Orange/Light Green LF+
Light Blue/White LF-
White/Light Green RF+
Dark Green/Red RF -
Pink/Light Green LR+
Dark Blue/Orange LR-
Pink/Light Blue RR+
Light Brown/Red RR-
(R-right, L-left, F-front,RR-right rear)
On the head unit, often, the yellow normally goes to the always on B+12 such as the + terminal of the battery, the red to a switched B+ such as the ACC of the IGN switch and of course the black to the chassis/ground.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Mar 22, 2008 | Car Audio & Video
NAD C355BEE Amplifier Logo
796 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
