Question about Cycling
I want to replace a crank arm for my Diamondback Recoil DS bike. The part number is Sugino 170-B8 (right arm).
    Brigadier General:
  • 8,546 Answers
It's not clear if you're just looking to source the part or looking for the 'how-to'.
Google works for both. You will probably NOT find an exact match right side crank by itself. THAT means you are not necessarily married to that model or brand or even size (170 is the length).
Check on eBay, too. "sugino crank 170"
There IS one used right crank coming due on 6/2/2011 for $22 and no current bids...
http://cgi.ebay.com/Sugino-GT-Crank-170mm-crank-BMX-/170646877602?pt=Cycling_Parts_Accessories&hash=item27bb58b5a2
You might be able to snipe it at the last few moments.
A bike shop could get you set up, too.
http://www.parktool.com/blog/repair-help/categories/bottom-brackets
Posted on May 30, 2011
Can you tell me what year and model diamondback this bikecycle is serial number is as01lo216o not 100% sure if they are zeros or o's
If the model is not right on the frame the bike has been repainted, which lowers its value. Year is not very important. Serial numbers are not very helpful, but you can try Google search for "Diamondback serial number". Also, see my tip: How to determine the year value etc of your bicycle
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 08, 2016 | Diamondback Cycling
Where to find rear swing arm bolt for coilEX
you need to go to a Diamondback or Raleigh bike dealer (they are the same company), they can order one from the manufacturer.
Jul 09, 2014 | Diamondback Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
How can a kickstand be mounted on a Diamondback Recoil?
Hi larryaw...
You can purchase the type of kickstand that bolts to the real axle and use it for your primary kickstand.
Please take time to rate me
http://www.amazon.com/Rear-Mount-Kickstand-Bikes-Chrome/dp/B001HBLEM4
Jul 27, 2011 | Diamondback Recoil Comp Full Suspension...
I cannot find a replacement nut that holds the crank pedal assembly to the sprocket for a Diamondback Cobra 24 bike. I have been to numerous hardware stores and can find a nut that fits the tread, but is...
You'll need to go to a bike shop and either purchase a new crankshaft (Less that $10) or, they may just give you a spare or two they have sitting around. It's a fairly specialized nut, something you won't find at the average hardware store.
Mar 06, 2011 | Diamondback Cobra 24 Jr Boys Mountain Bike...
Got a 1999 Diamondback Wildwood bike and was trying to take off the crankshaft and front sproket. Do I need a special tool for that? What's the trick?
Hi, yes you do need a special tool. It's called a Crank Arm Remover. The tool is basically a modified puller that threads first into the inside of the crank, (after the bottom bracket bolt is removed) where it is bolted to the bottom bracket. Then, a second bolt is then threaded inward against the tapered shaft of the bottom bracket. Slowly the crank will lift away from the tapered shaft of the bottom bracket. Hope this helps.
Nov 16, 2010 | Diamondback Cycling
Assemble diamondback bike
Unfortunately Diamondback makes it hard to get any info and it does not have a direct customer service email or Phone number you will need to locate either a dealer or service provider2_bing.gif in your area.
http://www.diamondbackfitness.com/customersupport.php
Apr 06, 2010 | Cycling
Won't come off other side of crank
Both cranks are pressured fitted on by the bolt being tighten. you need this took called a "Crank Puller"
Once you use the crank puller it will come off in a matter of seconds. you can pick one up for about $15
Good Luck!
Aug 12, 2009 | GT Bicycles Sugino Gt Crank Arm Black 175...
Cycling Logo
100 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
