Question about Speed Queen Washing Machines
Timer keeps on running. speed queen model ea2220wt serial r 9503066679
5 Suggested Answers
j_alcaidinho
  • 107 Answers
SOURCE: I have a Speed Queen Marathon washing machine..The
Maybe look on the belt, to see if there is a same number on it. take it to a appliance repair dealer get him or her to check for you
Posted on Jan 14, 2010
  • 714 Answers
SOURCE: model #HA4291WA won't spin
check your lid switch
Posted on Mar 01, 2010
caroldon
  • 17129 Answers
SOURCE: I have a Speed Queen top loader(older model). It
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Posted on Jan 13, 2011
rickyrt441
  • 4399 Answers
SOURCE: I AM TRYING TO REPLACE
Thanks for choosing FixYa and welcome. It is not coming loose? Is this your right model number? Thanks.
Posted on May 19, 2011
I have a speed queen electric dryer mod AES68AWF. i was in a hurry&turned the timer knob while it was running. it sparked a little & then went off. can it be fixed?
Should not have hurt anything by doing this as long as knob was turned clockwise while doing so. Did it spark around the knob itself. Stan
Apr 01, 2017 | Speed Queen Dryers
Hi i have a speed queen toploder washing machine
It might need to be rebalanced or your connection are not tight.
Feb 01, 2017 | Speed Queen Washing Machines
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
Speed queen AWN552 completed one load without a problem but machine won't start for 2nd load.
Does it fill with water? When you try to start a load, does the timer run?
Nov 09, 2012 | Speed Queen AWN542 Washer
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
Speed Queen Model SWT220WA 3/4 filled with water, loud buzzing sound, stopped.
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
Aug 28, 2009 | Speed Queen SWT921 Top Load Washer
NEED MANUAL FOR SPEED QUEEN DRYER MODEL 5T02205RG SERIAL LTCK 980800354B
Look on this page for your model
http://www.eaaxon.com/pdf.htm
Is Parts only mostly.
Aug 26, 2009 | Speed Queen Dryers
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWM 373 w3062w
I would start by checking the lid switch, you should hear a click when you open and close the lid. If this is ok we will move on to the timer.
The main power comes thru the timer when you pull out the timer knob the main power is fed to the machine. if you try and start the wash cycle multiple times will it occasionally work and then not. It so replace the timer. the p/n is on the back, it will be an RSPC number, typically 5 or 6 digits.
Then go to Partselect.com or repairclinic.com or a local parts house since you have an Export model for the Asian area I believe you may need to find someone local. The price on one I would think about 85 USD.
Let me know if you have questions. I can tell you how old it is if you send the serial number. Your choice.
T
Aug 21, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
