Question about Bissell Cleanview Helix Deluxe Bagless Upright Vacuum Cleaner 21K3
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
  • 276 Answers
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
Posted on Jun 01, 2011
There is little to no suction. What do I check to fix it?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Dec 24, 2010 | Bissell 3576 CleanView II Bagless Upright...
Bissell 8975-R CleanView Bagless Upright Vacuum - motor is loud when vacuuming
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>Hi,<br />Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...<br /><br />Bissell Bagless Upright <a href="http://www.fixya.com/support/t4975919-vacuum_pick_up" target="_blank">Vacuum</a> not working<br /><a href="http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not" target="_blank">http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not</a><br /><br />heatman101 <br /></span></span>
Aug 26, 2010 | Bissell 8975 CleanView Bagless Upright...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
No suction using extension hose for Bissell Bagless Upright vacuum. i checked for clogs and found nothing. shannon
Check the sole plate where the beater bar is. You may have to remove the roller brush flap to get into the roller brush and then check the main dust channel beside it. Usually if there's no suction on the hose it means that:
1) The hose is blocked 2) The filters are needing cleaned / washed and dried for 24 hours or see my tips! 3) There is dust clogging after the beater bar/roller brush.
Jul 18, 2009 | Bissell CleanView II Plus Upright Bagless...
Doesn't pick up: No clog seen
Change your belt as it is most likely broken, it takes a standard 7,8,9 belt in a green package. Also, it is very important that you clean the foam filters in that unit at least once a month. Dirty intake filters will decrease your suction wich can lead to clogging.
Jan 17, 2009 | Bissell 3576 CleanView II Bagless Upright...
Clogged hose by the brush roll
sometimes there maybe something interfereing with it getting clogged up repeatedly, etc....needle, paperclip....be sure to check to make sure nothing is interefering with the flow....i have seen this many times.....suction can be a problem from the motor but your motor will be noisey
Jan 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Cleanview Helix Deluxe Bagless Upright Vacuum Cleaner  21K3 Logo
143 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
