Question about Dell Inspiron 1545 Notebook
When I press shut down, the laptop screen gets off but the power button stays on and the laptop stays warm too. I have to press power button for 5 sec to turn this thing off. When I start it I don't get any shut down error message. I have Dell 1525 laptop running windows 7. This happened to laptop right after I transfered my sister's laptop files to mine via a cross cable.
    Scholar:
  • 97 Answers
Hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards Anas K A
Posted on May 29, 2011
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
WIFE USING LAPTOP, SUDDENLY SAID SHUT DOWN ,screen went black, but power stays on and will not shut down
Most of the time when a laptop or a PC does that it is over heating.
If you noticed that the CPU fan is going real fast and the laptop is pretty warm its probably overheating due to dust getting inside by the fan.
If it is buy a can of compressed air at your local store at push the air the opposite way that it is comming out.
Oct 27, 2009 | HP G60-120US Laptop
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Laptop power light is on, wont shut off and screen is blck
You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
Try reinstalling the operating system to resolve this problem
May 13, 2008 | Dell Latitude D600 Notebook
Stuck on asus logo on startup??
Same problem here with my wife's Asus laptop. Called Asus and they said to unplug charger, remove the battery in the back, hold down the power button for 10 seconds. Then, replace battery, then charger, then press the power button and wait for startup. First time it got stuck at the windows loading bar screen for like 5 min. which is abnormal. Did a hard power down (press and hold power button til it shuts off) then restarted again. That time it worked and all is well so far. Could have been due to a static charge as she was on our couch with our dog backing up movies so charge might have entered through the CD/DVD drive opening. (?) Not sure, but if you are sitting on a static-prone couch with your laptop its probably best to sit on top of a bounce sheet.
Apr 02, 2008 | Intel Motherboard
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Does not power stay on
try this with just the ac plugged in and the battery removed. Sometimes the battery, when fully discharged, can cause the system to shut down.
check your warranty here for Free
Feb 22, 2008 | Toshiba Satellite M35X-S149 Notebook
Dell Inspiron 1545 Notebook Logo
Alun Cox
