Canon iP4500 The ink absorber is full Contact the service center
  • 11,800 Answers
To reset the ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
To clean the pad you will have to disconnect the printer from the mains, move the heads aside, take out the pads with a long pair pf pliers (the black sponges that were under the heads) and clean them with running water until they are white. If you are careful and able to wait a few days you don't even have to take them out: just move the heads to the other side and, above the sink, pour hot water over them until they are clean; than drain all the water and leave the entire printer to dry for over a day.
Posted on May 29, 2011
The ink absorber is almost full contact the service center
Canon iP4500
Apr 07, 2011 | Canon Pixma iP4500 InkJet Printer
I have a canon iP1980.. it appears that ink absorber is full contact your service center..
I have a canon ip1980. It appears that ink absorber is full. Please contact service
Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
INK ABSORBER FULL Printer model - pixma ip4500 Please solve my problem
This is from the Canon web site.
Before the ink absorber becomes completely full, contact a Canon Service representative. (You will need to replace a particular part of the printer.)
i_important.gif Important
Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced.
There are some links on how to clean it yourself or to bypass the alarms on this site. Just do a search for ink absorber and you should find them. I wouldn't try this unless you are mechanically inclined.
Aug 26, 2010 | Canon Pixma iP4500 InkJet Printer
This error : the ink absorber is full.
You do need a service center to repair that for you. The ink absorber is underneath the printer and covers the whole bottom of the printer. If you just do a reset it will soon overflow and ruin the printer. You need a shop to be able to enter the service mode and reset the counter after the absorbers are replaced.
Feb 07, 2010 | Canon Pixma iP4500 InkJet Printer
Absorber is full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
My canon ip4500 says that the ink absorber is full contact the service centre
Hi ....
Do vote if this helps ... Cheers :)
Apr 29, 2009 | Canon Pixma iP4500 InkJet Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
