Maytag top load washer fills with water but dosent wash triend moving dial to rinse and nothing
    Master:
    Sergeant:
  • 385 Answers
You may have a bad lid switch.
Posted on May 29, 2011
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Will fill but not wash or spin
Does the motor run?  Does the water get pumped out at the end of wash cycle or during the rinse cycle or when you turn the dial by hand to the end of a cycle?  If the water gets pumped out then the motor is OK but the clutch is not working.  If the motor is not running then that is the problem.  If the water fills and then nothing happens (the dial does not turn by itself) the timer is bad.  If the timer is bad but you turn it by hand the other actions (wash, rinse, etc. should work indicating no problems with motor and clutch).
May 30, 2009 | GE WBSR3140DW Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
