Question about Watches
CANNOT GET BACK OPEN TO REPLACE BATTERY - Watches
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off. Pictures I've seen of your specific watch suggest to me that you have a snap-fit case back, though I'll include instructions about a screw-on back, just in case I'm wrong.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, modern snap-fit case backs are often very tightly fitted--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
If, on the other hand, you have a case back with notches in it, you will need to unscrew the back of the watch. You'll need a special wrench to do this. There are lots of makers and models from a basic $5 "watch crab" to a $100 workbench-mounted device that works on all kinds of watches, including Rolexes. Again, because screw backs are usually tightly fastened to increase water resistance, simply using a pair of needle-nose pliers in the ridges probably won't work. Nor will using a screwdriver in one notch--these backs are designed to move when equal pressure is applied around the edges, and applying force in one area only locks things up. Under no circumstances try to pry off the back if you have a screw back -- this will damage the threads, and you'll probably never be able to get the watch back together again.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for a pretty reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
If you can't close the watch case with your bare hands and don't have access to a case press, your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
Posted on May 29, 2011
How to replace a vestal zr3 watch battery
How did you open the back? Does it pop off or twist off?
Jul 07, 2013 | Vestal ZR3 Silver/Tinted Crystal...
How do I open the back of the watch to replace the battery & what type battery does it take? Thanks Ian Lawes
Usually the back of a watch is sealed with simple screws. Just unscrew them with a jeweler's screw driver and it will open the battery compartment of the watch.
The battery depends on what type of watch you are using. The most common batteries for watches are about less than 3/8 of an inch.
Mar 04, 2011 | Watches
How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
Battery replacement
do you mean you want to replace the battery for your watch?
This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
Good luck.
May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
How do I replace a battery on a kenneth cole watch and square fossil watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Kenneth Cole KC4232 Wrist Watch
I want to replace the battery in my chopard and i dont where
Open watch caseback. Undo the contact. Memorise numbers on battery and buy exactly the identical one. Replace the battery. Fit the contact back. Close the caseback. Reset the watch.
Mar 31, 2009 | Watches
Need to replace battery
Take the watch to a jewlers, let him replace the battery they usually only charge for the new battery,
and they do not cost much.
Nov 12, 2008 | Pulsar PXF182X Wrist Watch
I can't seem to remove the back casing on my Bulova watch in order to replace the battery.
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
Oct 25, 2008 | Bulova Watches
Concord Impresario battery replacement
The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
Aug 04, 2008 | Watches
How to take off back to change battery on pulsar v783-x009 watch
Don't even try. I take mine to the watch kiosk at sears. They open and replace the battery for a very reasonable price.
Apr 18, 2008 | Watches
Watches Logo
256 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
