Teac a 303 cassette deck = need to replace belts, how do you access the motor assembly?
Posted on Dec 05, 2008
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Shows err 3 on power up.
It could be belts or internal cam motor contact sensors. The transports that Teac sells are not direct replacements and DO NOT WORK.
Sep 02, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Teac a103 cassette deck. I want to know how much of this thing do I have to dismantle to replace the belts?? the online manuals ****!
It is not all that hard. You need to take the transport out of the chassis and then remove the screws required to get the motor mount and thrust plate off of the rear area of the flywheel. I have done them many times at Teac in the Chicago Factory Service. You need to get the right belt first. There may be more than one belt to replace in the unit such as one in the front near the counter. I can fix it but it might not be as cheap as you might think. I have been servicing Teac decks for 40 years so far.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Jan 19, 2014 | Audio Players & Recorders
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Getting belts for TEAC W-890R. I'm currently sitting here a home with a DEAD TEAC A-350 Cassette Deck -- DEAD because I was told you can get belts for it (I have since found out that is is NOT true and...
That is the state of conditions at Teac and they don't care about tape customer anymore. If you need belts for any unit it is simple to find the belt kit at Marrs Communications. They do not have he cheapest prices bu the you don't know what size you need and Fred took time to find his out. If you want to do it the other way you download a copy of the PRB cross reference manual and look up the belt type that goes into your deck. The you go to Ken's Electronics and order the belts online. This does not come with instruction of how to put them in. In my many years as a Technician working on all kinds of tape decks I have never seen an instruction to put belts in a machine- it is assumed that if you can not figure this out that you probably do not belong in the machine. In cases where belts are not in place sometimes the parts layout diagram can help you determine how they go in.
I am an ex Teac Lead Technician from Chicago.
Aug 25, 2013 | Teac W-865R Single Cassette Deck
How to replace the belts in a Teac A300 cassette deck
The mechanism needs to be taken apart sufficient to get to the flywheel and capstan motor- this usually entails taking the metal motor bracket off the back. It is not that difficult once you have done one. I may have replaced 50 to 100 of them at Teac in Chicago. Also oil the capstan bearing when changing a belt.
Aug 08, 2013 | Teac Audio Players & Recorders
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Oct 08, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
478 people viewed this question
 Grubhead
Grubhead
