Question about Goldstar DH304 Dehumidifier
Stopped running - Goldstar DH304 Dehumidifier
    President:
  • 2,468 Answers
Replace the full bucket switch located above where the bucket sits these go bad because all the power goes thru this switch and they go bad quite often
Posted on May 29, 2011
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
My dehumidfier runs for about a min and then stops running
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit still stops running after a min, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 12, 2010 | Goldstar DH304 Dehumidifier
Can you please help me find out what makes my fan motor slowly stops running after about 30 minutes. The unit runs fine but after about 30 minutes the motor sounds like it slowing down and wants to trip....
mcdevito75 here, It could be the capacitor if you can replace with same size do so. The Armature or communtator in the motor could be shorting also, do the capacitor the change the motor.
Jun 23, 2010 | Dehumidifiers
Unit Changes Speed While Running
It may be slowing when the compressor starts, you may want to check the outlet it's plugged in to.
Jun 17, 2010 | Kenmore 53701 Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
Runs, stops collecting water.
check defrost cycle and give me thumbs up
Aug 08, 2009 | Dehumidifiers
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Goldstar DH304 Dehumidifier Logo
44 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
