Question about D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router
HOW DO I CHANGE THE CHANNEL OF D LINK ROUTER - D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router
    Master:
  • 451 Answers
Login to your router via your browser to 192.168.0.1
login/pass admin/admin
click on setup, wireless settings
click on the dropdown list next to wireless channel to change the channel.
Posted on May 29, 2011
Where do I go to change router channel?
You can find the user manual for your router here:
http://www.dlink.com/products/?pid=DIR-655&tab=3
To change the channel, look on page 10 of the user manual for directions on how to access the web interface of the router.
Once you get logged-in to the router, you can then go to page 22 to change the settings for the channel. You'll want to disable "Enable Auto Channel Scan" and choose 802.11g as the "802.11 Mode". Then choose the channel you require from the "Wireless Channel" selection.
Nov 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How can I change the channel selection on my router....it keeps dropping the internet signal. Is there something else I should try?
In order to change the wireless channel of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless Network Settings under which you can change the wireless channel and click on save settings at the top .
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
My phones run with 2. Ghz frecuency so when I used my inalambric phones get disconnected from the web, how can I solve this problem I have a router model F5D 7230-4
On all wireless routers there are channel settings. If you phone is on the same channel, you may have problems with the router. Also make sure your base station to your phone is not next to the router. Its radio waves may cause interference. First thing to try is to change the channel number for your wireless router. See the attached link for your router information and how to change the channel.
The link is: http://en-us-support.belkin.com/app/answers/detail/a_id/76/q/routers
Good Luck.
Jan 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to change channel on actiontec router
Log in to your router. Select Wireless Setting then Basic Security Settings. Item #3 is the channel. Select the channel you want, then select Apply at the bottom of the page, et voila, you'll have your new channel. Good luck getting a better S/N ratio.
or follow this link
wordnet.princeton.edu/perl/webwn?s=tune
Nov 13, 2009 | Actiontec (GT704WG) Router
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I recently bought a Dell laptop that has B+G wireless networking. Should my 2300 router work with this computer? I am having trouble getting a signal to my work area.
yes you can work with it.
If you face problem in gettings signal strength then you need to change frequency channel in router.
for that access your router with following link
If it is not in netwrok then connect your router to computer with ethernet cable.
Then access thisd link http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as."admin" or blank or "password"
then if you cannot access it then you have to reset your router to factory defauls settings.
For reset you have to press RESET button for 10 seconds it is in back side of router .
then access with above link
then go to wi fi and change channel type to 4 or 6 or 11 try 1 by 1 then save settings in router then restart bot computer and router to then check signal strength set that channel which give you high signal.
Aug 13, 2009 | Dell TrueMobile 2300 Wireless Router...
D link D524. No range.
You need to change the Wireless Channel on your wireless router. Open the router's setup page by going to http://192.168.0.1. It will prompt you for username and password. By default username is admin and password is password or no password. When you have the router's setup page opened, look for wireless tab and look for Wireless Channel. You must change it to 11 or 6 or 1 then save the settings. You can play around with the channel and find out which one gives you better signal. If you're still having low signal range, try to reset the router back to factory defaults by pressing the reset button at the back of the router for 30 seconds and do a power cycle. Just reconfigure the router after resetting it.
Jul 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Wbr 2310
By default the channel is set to 6. The Channel can be changed to fit the channel setting for an existing wireless network or to customize the wireless network. The Auto Channel Scan setting can be selected to allow the WBR-2310 to choose the channel with the least amount of interference.
Oct 06, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Gaming
hello!
-- what is the exact model number of your router?
-- what is the operating system of your computer?
-- are you trying to change the channel wirelessly or directly connected to the router?
1. make sure that your computer is directly connected to the router while changing the channel to avoid frequent disconnection.
Apr 26, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link WBR-1310/RE 54Mbps 802.11g Wireless LAN/Firewall 4-Port Router Logo
2,440 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
