Question about Maytag Neptune MAH5500B Front Load Washer
I have a Maytag model MAH5500B that starts to fill , stops and LR appears in indicator lights. Any suggestions?
    President:
  • 2,468 Answers
Remove the belt from the motor pulley and make sure motor spins freely,check the 3 windings with an ohmmeter for appx 8-11 ohms each,then check all connections everywhere by removing and reinserting them,then try to run the diagnostics from the tech sheet inside the washer,if all this fails then replace the M.C.U. motor control unit
Posted on May 29, 2011
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
It stopped & say's Lr. ???
The answer that I receive from Fixya.com was correct, and very helpful.
When I tried to find a store to replace the washer, I found that this model had been discontinued. This is the 3rd. time in 10 year that I have owned this model that we have had a problem with it, and it has been very costly to us.
I decided to buy an LG. this time. Screw Maytag!!
Dec 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lr code appears. machine stops.
replace or, replace the lid lock switch,solenoid or, bent lock lever
Jun 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer mah5500b
Replace the door Wax motor & main Control Board.
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
No spin
Code Lr indicates a fault or failure with the motor. Manual refers user to contact a service rep. First check your warrantee and do a look up on recalls (you can use the Maytag homepage) as some of the earlier versions of this model were recalled and Maytag has agree to some forms of restitution/repair and or replacement assistance.
Dec 10, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune fronmt load washer Model MAH5500B
Lr means locked rotor basically you have serious problems i would call a service tech for this.
Sep 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
