Question about General Hand Tools
How do i change the assesories that come with dremil how do i use the hand held dremil??
    Genius:
  • 1,015 Answers
If you have the standard dremel tool ther is a small bar sticking out at the collet end of tool. This is a locking rod to hold motor shaft in place so you can loosen coollet nut. Put pressure on thebar and slowly rotate the shaft until the bar drops in place. There should be a small open end wrench that comes with your tool to loosen nut. If not use asmall wrench to loosen nut.Turn it counter clock wise to loosen. It is not needed to take the nut all the way off. You may have to move tool slighyly to get it to come out.
The tool that you use is determined by what job you are trying to do.Most come with abrasive cut off wheels small grinders,sanders,and polishers.To secure new tool in collet just insert tool shaft in collet and tighten down. When it gets snug then Depress locking bar to finish tightening. Hope this helps you some. Thank you.
Posted on May 29, 2011
Change the batteries in my hand held can opener modelS1212
Put both thumbs in the center of the flat side (the bottom). Apply downward pressure and move your thumbs toward the "tail" of the can opener to slide the bottom off and reveal the battery compartment.
Sep 23, 2014 | Kitchen Appliances - Others
How to put screw back in the end of a dremil
Take the screw out and look for cross threads. look inside the shaft and gently tap the outside to see if ther is smoething wedged in it.
Feb 27, 2014 | Dremel Tools & Hardware - Others
The hand held remote no longer activates the ceiling fan or the light. I know I have power to the unit and know that the battery in the remote is ok. When I press the remote for the fan or lite the red...
If you only change the battery in the hand-held remote, there should be another one in the fan housing that also needs changing. Always change all the batteries at the same time.
Apr 04, 2011 | Hampton Bay Heating & Cooling
How do i change the car key batteries?
Disassembling and assembling hand-held transmitter
NOTE: The top part of the hand-held transmitter is carefully lifted off with the fingernail or a small screwdriver.
Removing key from the bottom part
  1. In order to remove the key from the bottom part, the compression spring in the sliding latch is compressed and held with a small screwdriver.
  1. Lift out the cap and relieve the compression spring.
  2. Push the sliding latch back and pull the key out of the bottom part.
Installation
  1. Insert replacement key into the bottom part.
  2. Install sliding latch and compression spring. Compress and hold compression spring using a small screwdriver.
  3. Insert the cap from above and relieve the compression spring.
  4. Press the top and bottom parts of the hand-held transmitter together firmly.
Nov 12, 2010 | 2003 Porsche Boxster
Shower - Rain head won't turn off so hand held can be used solo.
Probably the fitting is not working properly. Please change the fitting.
Apr 17, 2010 | Plumbing
Out of range
Unplug it - take battery out of hand held unit - for several minuets..
Put it back and power up..
If issue still there - there is a channel selector on the hand held unit.. Try changing channels..
If the battery is week in hand held this could happen.. These batteries last around a year +/-.. You can get a replacement online,, WalMart,, Radio Shack..
There could also be interference in the area..
Have a great day !
Oct 26, 2009 | Uniden Cordless Phone
"hand" icon flashing
It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
I have a desktop dell runining XP software. I have a tungsten E hand held. I cannot get the contacts on the handheld to appear on the screen of the desktop. I just tried putting a new contact in the desk...
Try right click on the Hot-Sync icon, on the Taskbar and select Custom then select Address book and change the Action to Synchronise the files. You might have to use Windows Explorer to view your contact. I'm not 100% sure about this one but try it anyway.
Mar 19, 2008 | Computers & Internet
Hand Tools Logo
74 people viewed this question
Top General Hand Tools Experts
Bill Boyd
Are you a General Hand Tool Expert? Answer questions, earn points and help others
