Question about Refrigerators
Kenmore model # 2571832104 water is leaking inside from Refrigerator control. I have a container catching the water. Was away for a month and crisper baskets were completely filled with water. Drain pan has some water in it. did see some condensation & some ice around refrigerator control. I turned off frig for 4 hrs and back on...still same issue
    President:
  • 2,468 Answers
The evaporator drain is plugged up and when it defrosts it overflows down thru the damper vent door into the refrigerator compartment you need to remove rear inner panel in freezer and get drain hole unplugged with a wire
Posted on May 29, 2011
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Water leaking from top of kenmore refrigerator model 253
Almost certainly a blocked drain hose. Hose can usually be accessed from the back, it drains to a catch pan, usually on top of the compressor/motor. Best unblocked with a blast of compressed air if you have a compressor otherwise feed a long piece of whipper snipper chord or similar up from the bottom to dislodge the blockage (and/or down from the top if you can access the drain hole from where the leak appears inside the fridge). Good luck, hope this helps.
Nov 15, 2013 | Kenmore Refrigerators
We have a Kenmore Model 57577791 refrigerator. It's almost 13 years old. For about 6 months, it hasn't been dispensing water. It makes ice, but constantly freezes up right where the ice goes out...
Water is only in the line, theres no tank so one cycle will get rid of any old water, then you can just throw those ice cubes away. The way to fix the problem is to replace the solenoid fill valve on the back bottom corner of the refrigerator, Thats the thing the water hose connects to. It has a slow leak that is causing the ice to build up in the tube. Good luck.
May 29, 2011 | Refrigerators
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
