Question about Sta Rite 1HP Above Ground Pool Replacment Pump 6' Cord NE641
Hi, my names steve and when i turn my pump on for the first time this year it just hummed.
    President:
  • Sta Rite Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor if one is present. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
Next check the internal stationary start switch for continuity thru the contacts. Bent or burned up points and arms can cause a startup failure...you may need a new part if yours is more than bent out of position.
Finally check the winding for grounds and shorts...if you find any it is most likely time for a new motor.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on May 30, 2011
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
Maax Hydro massage bathtub Model 05-001, electric motor hums but does not turn, what is the fix?
If your pump is just humming this is an indication of a bad motor. You will need to provide the name of the pump and a model number to the supplier so they can match up the exact replacement for you so you won't have to re-plumb to put it back in.
Rod
US Parts Center
Jan 14, 2014 | Maax Home
No steam is coming out anymore
hi
it a sign of the pump ceased up or the electric motor faulty capacitor .
check if you can manually turn the pump freely and then check the capacitor
Dec 18, 2017 | Mr Steam Electrical Supplies
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
94 GMC Truck Fuel Turn key and 1 out of 10 times the fuel pump will hum and you can start it. Any ideas to look for?
It could very well be your fuel pump about ready to fail. There is also a fuel pump relay that you could easily replace and try. It should be located in the engine compartment. Your question has two different years listed so it could be in different locations depending which year you have.
May 14, 2011 | 1996 GMC Sierra
I have a intertherm furnace and split intherm heat pump when i turn the thermostat on it just seems to hum out side at the heat pump whats the problem
First thing to check is to see if you have electric out there. The hum is probably the 24 volt relay that is telling the a/c to come on. The 24 volt relay gets it's power from the indoor unit.
Jul 06, 2010 | Intertherm P3RC-030K Air Conditioner
2002 buick rendezvous fuel pump not working
if you heard the pump befiore ( that hum near the rear) than most likely the pump has burned out , i would have it tested and replaced if needed
Aug 29, 2009 | 2002 Buick Rendezvous
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pump will not start and it just hums. When I
if it has been sitting since last year, some rust could have kept the shaft from turning. Get some pump pliers and try to rock the shaft. after you get it freed up, turn it back on.
David
May 09, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Sta Rite 1HP Above Ground Pool Replacment Pump 6' Cord NE641 Logo
161 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
