Question about GE Washing Machines
WHERE IS THE WASHER PUMP FILTER ? - GE Washing Machines
The pump filter is located in the panel right underneath the front door, there three screws which you have to unscrew. Once you have opened this panel it's a white knob on the right hand side, when you open it water will come out of it as well as junk that's been stuck in there, at least that's what happened to mine...I had the same problem
Posted on Jan 21, 2009
F21 error on Kenmore washer
The F21 drain indicates a long drain. There are several reasons for the error. The most common causes are debris in the drain pump filter or excessive suds. If you aren't using HE detergent or if you use too much detergent, the excess suds may be the cause. First, remove the clothes from the washer. Try running the washer without adding more detergent.
To check the filter, you will need to unplug the washer. Next take off the bottom panel. Locate the drain pump and the adjacent filter. Have a bucket handy to catch the water from the pump. Open the filter and remove any foreign objects. Look into the pump and check for any objects that got past the filter. Remove anything that doesn't belong. See the cabinet and pump diagrams here: http://www.searspartsdirect.com/model-number/11049972602/0583/0153200.html to help you take apart the unit and locate the pump filter. Close up the filter and try running the washer (again no clothes and no detergent). If the error does not recur, you've solved the problem.
If the F21 error repeats, then the pump or the water pressure switch could be faulty. If water has been pumped out of the washer, then check/replace the switch. You should also check the wiring between the switch and the main control board.
I hope this helps.
Jul 26, 2016 | Kenmore Washing Machines
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
How do I clean the washer pump filter in my GE-WCVH6600HGG?
please go through this http://www.youtube.com/watch?v=x7rJkWE0nN0
Instructions:
  • Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running
  • Open the pump access door with a coin. Remove the pump filter by turning it counterclockwise and pulling it out.
  • Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean.
  • Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
  • i hope this helps you ,thank you
    Feb 10, 2011 | GE Washing Machines
    Engine runs , not getting any water flow when trigger pressed.
    Disconnect hoses.
    Look for kink in water hose.
    Check incoming water connection for filter washer
    Replace filter washer
    If you don't have a filter washer, put one in.
    Hook up water, and turn on
    Water should come out other side of pump.
    Turn on machine.
    Do you get pressured water out of pump.
    If no pressure, then pump is suspect
    Hook up washer hose without gun
    Does pressure come out of washer hose
    Finally, the gun trigger may be bad.
    We had to buy guns now and then.
    Search for pressure washer guns
    Following link shows guns we used:
    http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
    Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
    Were is the drain system manualy
    To access thr pump and filter, remove lower rear cover of washer.
    The pump and filter are located at the bottom rear right of washer.
    To clean filter, remove large black hose onto drum, and clean filter inside hose.
    Hope this helps.
    Jan 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
    I have a duet sport wfw8300 it does not finish cycle and it flashes F 21
    F21 = LONG DRAIN
    If the drain time exceeds 8 minutes the water valves turn off.
    Press PAUSE/CANCEL two times to clear the display.
    If you had this washer for sometime the most likely cause is Item 4. If so remove the lower front panel place a pan under the white filter (before the pump)
    remove the filter and clean and remove any foreign material and reinstall filter.
    else
    1. Check the drain hose and make sure it is not plugged or kinked.
    2. Unplug washer or disconnect power.
    3. Check the electrical connections at the pump and make sure the pump
    is running.
    4. Check the drain pump filter for foreign objects.
    5. Plug in washer or reconnect power.
    6. If the above does not correct the problem, go to step 7.
    7. Unplug washer or disconnect power.
    8. Replace the pump.
    Oct 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    My washer gets so far then says fp
    fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
    Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
    Whirlpool washer pump inlet filter
    No, there is no filter before the pump inlet.
    Sep 07, 2007 | Washing Machines
    Washing Machines Logo
    93 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
