Question about Zanussi Ovens
How to fit a rubber seal on the lower oven - type A9677/134, serial 03816920, prod no 949700077-01, model no ZDF 866B. How to remove the old seal would also be beneficial as it is torn. Thank you
barkencoa
  • 3463 Answers
SOURCE: How to remove a fan/motor from a Zanussi oven
You are probably trying to undo the nut the wrong way.
It is a left hand thread, so to undo it, you go clockwise, as though you were trying to tighten it, and vice versa to tighten it up again. If you can't unscrew the nut, you will have to grip the fan spindle with something whilst you undo the nut.
Plz rate my solution.
Thanks.
Posted on Jan 22, 2009
  • 42 Answers
SOURCE: Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Posted on Sep 28, 2009
  • 401 Answers
SOURCE: i need to replace the lower heating element in my
YES IT IS EASY BUT UNPLUG IT FIRST. REMOVE THE SCREWS FROM THE BACK WALL ABOVE THE ELEMENT AND SLOWLY PULL THE WIRES WITH THE ELEMENT THROUGH THE WALL ABOUT A INCH AND DISCONECT THEM FROM THE ELEMENT
Posted on Jan 12, 2010
iwillfixforu
  • 619 Answers
SOURCE: I need to replace the seal around the glass in the
Usually just a phillips head will work. Only other screws may be torx screwdriver but it is usually a phillips head.
Posted on Feb 01, 2010
  • 193 Answers
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
How do I fit a seal to an Electrolux oven with rounded corners and no clips
Good Afternoon friend, thank you for your post!
I understand that you need help with the seal on your Electrolux oven. Could you provide me with your model number, please? The serial tag is located on inside wall of your oven. With that information I can provide you further assistance. -Matt
Feb 12, 2015 | Electrolux Ovens
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
Hello we have a fisher and paykel classic stove and top with four elements model no RA610MAW as we are in the bush we need to know how to change the seal in the oven which the door closes on we have the...
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Mar 19, 2010 | Fisher Ovens
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Ovens
I need to replace the lower heating element in my older model oven. I think the serial number is 316071601. How do I remove the old element? I am clueless at repair but this should be relatively easy to do...
Jan 12, 2010 | Frigidaire Ovens
Sep 28, 2009 | Ovens
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Thanks.
Jan 22, 2009 | Zanussi ZHQ575 Electric Double Oven
New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Dec 19, 2008 | New World G90m Gas Double Oven
Ovens Logo
Top Zanussi Ovens Experts
ashburton
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
