Question about LG HFB500 Car Handsfree Kit Wireless Bluetooth
How do i connect my bluetooth handsfree modle AVHB04 with my micromax mobile
Micromax bolt x321 handsfree problem
micromax x321 headphones jumper
Dec 01, 2013 | Cell Phones
Samsung c3050 mobile not connecting to bluetooth handsfree device
There probably is a special procedure for connecting the second device. Consult your user manual for the headset and be sure to follow the steps precisely.
Dec 17, 2011 | Samsung C3050 Cell Phone
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
My plantronic bluetooth not connecting.
1. You have to keep the on/off button on plantronic pressed for almost 1 min.
2. You will see the blue and red light flashing on it repeatedly and then try to locate the handsfree on your mobile handset;
3. Now you will be able to see the bluetooth on your mobile and then you will be able to connect it throught;
4. In case it asks for a password enter 0000.
5. Once connected you will hear a beep in your ear; this confirms connection;
6. Ensure your bluetooth handsfree is charged properly.
Try and rank me if you succeed.
Jun 09, 2011 | LG Cell Phones
I have a bluetooth plug-in handsfree car kit model#bthf0082 it asks for 4 digit pin on mobile when i try to connect device?
HI, TRY CODE 8888 ON YOUR MOBILE PHONE TO CONNECT THIS BLUETOOTH DEVICE BTHF0082. HABIB
Mar 09, 2011 | Cell Phones
I cant connect to my cell phone
power up handsfree kit turn on bluetooth on mobile device and 3200 should be found and pair
Mar 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have a Logitech bluetooth headphone. And I had to buy a new PS3. I threw away the manual to setup the headphones. Can you tell me how to set it up?
Your passcode should be 0000 (four zeros)
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Jan 15, 2010 | Motorola Mobility Logitech Mobile...
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
How to connect my nokia BH-104 bluetooth handsfree to N73 mobile
Most handsfrees need you to hold the on button for about 10 seconds to trigger the pairing. Hold the button until the indicator flashes rapidly.
Oct 03, 2009 | Logitech Bluetooth Wireless Talking Kit...
I need a user manual for thisSFK404 Bluetooth Visor Mount Handsfree Speaker but I cant seem to find one online so i could download it
didnt find any either too old but here is specs.
Model No: SFK404
Simply attach the Visor to the Sun Visor or any other suitable place, connect the Bluetooth hands free kit up with mobile and away you go.
Superb Quality simple Bluetooth Car Kit with Caller Id Display and Number Keypad for easier dialing.
Specifications
* Talking Time : 5 Hours * Standby Time : 150 Hours
* MIC : -47+/-1.5 * Power Consumption : Max 250mA
* Carrier Frequency : 2400MHz to 2483.5MHz * Transmission Power : Typ.1.0 dBm
* Operating Temperature : -20 ~ 70? * Storage Temperature : -40 ~ 85?
* Speaker : 8W, Max 1.5W * Digital Volume Control
* AC/DC Adaptor : 5.0V / 1A * Car Charger : Out : 5.0V/800mA
* Battery : 3.6V, 950mA Li-ion Rechargeable NK8200 series compatible
Main Functions
*Superior noise suppression *LCD Display - Caller ID/Calling time
*Excellent echo cancellation *Support Making/Ending a call
*Super full duplex *Support Voice Dialing, Number Dial
Compatibility : Compatible with all Bluetooth mobile phones
Profile : Supports for both Headset & Handsfree Profile
Bluetooth v1.1 compliant
CSR(BC02)
CDMA & GSM & TDMA
- Approvals : SIG, CE, FCC certified
FEATURES :
Last Number Called
Voice Dialing ( Providing the Phone Supports the feature.
Number Dialing
Speed Dialing
Selct wether to answer, Reject and End Calls
Volume Control
Power On and Power Off Feature to reserve battery power.
Rechargable Battery
Battery Power Status
Incoming Caller Alert ( Visor will Play a Meldoy and the Led Display will Flash Blue )
Connect to Pc for firmware upgrades ( Cable Supplied )
Bulit in Speaker
Built in Microphone
Bulit in 4Mb Memory
Noise Suppression
Echo Cancellation
Supports both Headset and Car Kit Profiles ( Phone Dependant )
Transferring Audio Feature ( Both from Headset and Handset )
Standby 150 Hours ( Uses a Nokia 8210 Battery so you can have a spare battery or simply purchase any nokia phone model in car charger to charge from your car. )
Talk Time 5 Hours
1 Year Warranty
Compatable with all Bluetooth Enabled Mobile Phones.
Handset supporting headset profile
Ericsson: R520m / R520m, T39 / T39m / T39mcc, T68m / T68mc
Sony Ericsson: P800, T68,
Motorola: A803, T280i, TimePort 260C V1.1
Philips: Fisio 825/826
Samsung: X7700
Sky: IM6200
Handset supporting handsfree profile
Motorola: V525, V600
Nokia: 6310 / 6310i, 8910 / 8910i, 3650, 6230, 6600, n-Gage
Sony Ericsson: T68i / T68ie, T610, T613, T630, Z600
Siemens: S55, S56, SX1
Panasonic: X70
Jan 22, 2009 | Cell Phones
LG HFB500 Car Handsfree Kit Wireless Bluetooth Logo
43 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
