Question about Dryers
My Hotpoint Aquarius Condensor Dryer seems to be collecting water behind the filter unit at the bottom of the machine. The drawer where the water is supposed to collect is empty. I keep the filter unit clean and I have checked that all the pipes are connected at the back of the dryer. I suspect some sort of blockage - but where?
    President:
  • 3,074 Answers
There is a line/tube the runs into the back of the drawer which is clogged, you will need to take like pipe cleaner or a stiff wire and run it into the the drain line/tube , Tim
Posted on May 29, 2011
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
No water collecting in my hotpoint aquarious cdt00
If you pull out the front left bottom filter and feel inside and find that it is wet, then there is a blockage, this stops the water getting to the water container.
Clean as much fluff and gunge as you can from this compartment, and feel for and locate a small drainage hole at the rear, get a plastic bag tie or similar, and poke the hole clear.
Hopefully, this will solve your prob.
Plz rate my solution.
Thanks.
I am assuming that the pump is working o/k
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wt741
In most machines the filter is located under the panel in the bottom of the machine (the panel under the front door).
If u have manual refer; pull the panel out and you will find the filter there.
Before you open the filter keep a bowl & cloth to collect much water.
Mar 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
Aug 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
228 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
