Question about Ryobi Garden
My ryobi 31 cc gas trimmer will only start and run with the choke engaged. When I open the choke it stalls. I have cleaned the filter and checked the fuel lines. every thing seems to be OK
    President:
  • 3,074 Answers
Check the spark plug if fine, then an 1/8 of a turn on the screws until it runs correctly, Tim
Posted on May 29, 2011
Will only stay running on full choke
Your fuel is likely stale (replace all of the fuel, including the fuel in the gas can that you used to fill the trimmer), and/or your air filter needs to be cleaned.
May 14, 2015 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Will not stay running
How dose it run with choke on Half? I would try adjusting adjusting air fuel mixture, but make sure you have clean air filter in it before any thing else.
Mar 29, 2014 | Ryobi 22 in. 26 cc Gas Hedge Trimmer...
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi lawn trimmer keeps stalling out. I have
If it is a relatively new unit it should have the carburetor adjusted after the first few hours of use. If it stalls upon accelleration the low speed adjustment on the carb needs to be opened a little bit. If it runs a few minutes and then stalls it could be the high speed jet needs to be opened or the fuel filter is clogged.
Sep 16, 2009 | Ryobi Garden
My weedeater starts but doesnt seem to be getting enough fuel
You can't clean the filter. You can however order a new filter with the filter attached from www.ryobi.com.
When you say it's not getting enough gas is the weedeater shutting off on you? If so your carb may need to be clean. If that's the case then report back and I can tell you how to do that.
Mike
Aug 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
305 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
