Laptop hanging when i connect charger. Laptop is using with battery no problem.
  • 5,568 Answers
The charger for your system may be producing a level of electronic noise due to weakened components in it and that noise may be getting into your system and causing the random lockup. If you have a portable radio with the frequency band for AM (~600-1700 KHz) turn it on and hold it close to the charger while it is plugged into the AC and the laptop. Tune across that band to see if you have a prominent signal from the charger. If you find noise in that band, just pull the radio slowly away from the charger to see if it decreases. Then set it closer and pull the AC plug. If it ceases, the charger is going bad and you will need a new one to defeat the ransom lockup of your system.
Posted on May 29, 2011
  • Steve Allison
    Steve Allison May 29, 2011
    Typo: > ransom lockup
    This should read "random lockup"
  • 30 Answers
Your questions makes no sense, please re-word it
5 Suggested Answers
lincen
  • 6 Answers
SOURCE: Dell Laptop Battery Charer
Generally the LI ion material is nucleus in the laptop battery inside, It with suited manage power supply electrocircuit make up of laptop battery. It’s encase in the laptop inside charge and use. result in because high temperature condition work on long time. But the LI ion battery apply use condition temperature 25-30℃ confine. Therefore at laptop host computer temperature high attain 40℃ usually, so have existence blast or combustion latency safety problem and shorten use life the battery.c
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
Posted on May 04, 2009
leecom72
  • 4806 Answers
SOURCE: A humming noise when my battery is connected to the laptop.
Hi there.
The problem is battery if the machine works on AC power only, you will have to get a new battery or continue to use it on mains power until you can get a new battery.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
rh10
  • 122 Answers
SOURCE: Hot laptop and battery charger
It may well be that the battery that's being charged is getting past its sell by date. They only last for so many charges. easy way to find out is remove the battery, connect the power supply, and if the charger power supply doesn't get hot (usual to get warm) then its your battery. It is perfectly okay to use the laptop without the battery installed on the mains.
Posted on Jul 15, 2010
  • 30 Answers
SOURCE: My HP 6715s works fine but wont charge?
Hi there
this is just a wild guess but i think that is you ac conector that is fry there is not fuses for that so the only option is to take it to a local repair guy an get it replace. depending where you are may run from $50 to $150 the repair since they have to take apart the laptop to change it the part is no more than $ 15 but labor is the costly here so maybe the docking station will be the best in your case .
Posted on Jul 28, 2010
I can remove my charge. application will hang are some lagging.
Whats the operating system on this laptop? I asked this as u unplug the computer Win VISTA will slow down and cause other program to not run in general, the setting can be changed in control panel settings. Or upgrade O/S to Win 7.
May 24, 2015 | Compaq Presario CQ60-220US PC Laptop
Hcl me laptop 39 s.no.1104ax259318
Battery issue? Try a fresh battery.
Feb 06, 2014 | Computers & Internet
Charger hang laptop
Check the voltVoltage too high and the laptop shuts down to protect itself, too low and it won't work.
If it states 19.5vplts, that's what it needs.
Nov 21, 2013 | Dell Vostro 1400 Notebook
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My laptop is hang when i take away from one side to another side or ****
there is some loose connection in motherboard which caused this hang problem, you need technical assistance to fix this issue
May 12, 2012 | Compaq Presario CQ40 Series Laptop Charger...
My laptop hangs everytime i use the power supply (adp-75sb ab) provided for this unit (toshiba satellite a205-s6808) but when i start my laptop with the battery, everything works out fine. it only hangs...
Check the voltage output from the charger and see if it is within the range that is stamped on the charger body (eg: 20 volts) If it is below or above this, then the charger is faulty. If the green light is flashing on the charger, it means that power is "not being accepted" by the laptop and this indicates a faulty charging port / circuit.
Jan 18, 2011 | Toshiba Computers & Internet
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
My gateway m1622 shuts down on its on wat can this be
remove battery and try charger bad battery will hang up charger
Jan 09, 2011 | Gateway M1622 Garnet Red Laptop Charger...
WAS MISSING CHARGER, but was running on battery. will not charge battery or power up, no lights. Battery went dead MT6821 GATEWAY
All you need to do is be sure whu will need to replace both.
If the problem is with either the charger/battery you will need to figure that out first.
Please have the battery charged of your laptop, and try using the laptop only with the battery and without the charger, If it works fine you will have to check the charger now.
In order to check the charger, please take out the battery from the laptop, now connect your charger to the laptop and try switching on the laptop. If it does not work then your charger is faulty.
You can purchase the accessories online at various portals. I am providing one of the portal information:
http://www.laptoptraveller.com/battery-gateway-mt6821-laptop-notebook-accessories.html
Sep 01, 2010 | Gateway Computers & Internet
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
