Question about GE APH10AA Air Conditioner
I emptied the water and the e4 is still on and wont blow any air....whats wrong??????
    President:
  • 3,074 Answers
You will need to find the sensor/switch, which is in the housing where the drain bucket is located, it is either stuck or shorted. Good Luck Tim
Posted on May 29, 2011
Getting an E4 Code and the air is not as cool as the temperature reading indicates. How to fix?
I think it is low on gas. You will have to call the repairman on this one. If it is real old, just replace it.
Jun 09, 2015 | Heating & Cooling
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
I have a comfort aire pac-121 and the display is reading e4 and the ac is not working. i can't find a manual on line. How can I fix the problem? thanks andy
I have the same model, though several years old, and on mine E4 simply means the reservoir is full. Try emptying the reservoir tank and then turning the power on again. If the drain hose outlet isn't angled down, the water drains into the tank, which will need to be emptied regularly. (For constant use, may need to be emptied several times a day.)
Jan 15, 2011 | Comfort-Aire PAC-121 Air Conditioner
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
Shuts off, error code e4
i THINK e4 CODE ON SOME MODELS means that the water drain pan need to be emptied.
Jul 10, 2009 | Heating & Cooling
E4 Error code on APE07AHM1
I emptied the water tray. Viola!
Jul 16, 2008 | GE APH10AA Air Conditioner
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Kenwood KW85 Air Conditioner
Start the unit and press the remote control at C if the display in the unit displays C, then turn off the unit using the remote control and plug out the ac supply. Plug the unit again and using the remote control turn on the unit. If the E4 still display there is something wrong with your air in sensor or the main board itself. Replacement of this parts needs a qualified technician.
Aug 30, 2007 | Kenwood KW85 Air Conditioner
E4 error being displayed
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
GE APH10AA Air Conditioner Logo
216 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
