Question about Mtd LAWN MOWER PART # 983-04053-0637 DECK Assembly-SD 46" GT Color POWDER BLACK
MY MACHINE NO STAR, I HAVE YARD MACHINE BY MTD 21' CUT 6.75 HP ENGINE 190 CC. SERIAL # 1F296K10770. HOW I KNOW WHAT HAPPENS? & HOW I DO MAINTENANCE?
  • Mtd Master
  • 7,482 Answers
Hi mary pineda2...
Try these solutions to fix your problem with starting...
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 29, 2011
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Diagram for belts on a 48 cut yard machine
http://www.ereplacementparts.com/mtd-13aq617h118-2003-lawn-tractor-parts-c-20039_20060_133253_24406.html MTD 13AQ617H118 2003 Lawn Tractor Parts
May 13, 2015 | Yard Machines Garden
What kind of oil shoukd I use on a 24"cut MTD yard
I'm assuming you have a Tecumseh engine on there. But a Briggs would be the same. This is straight from Tecumseh, though (long story short is run 5W30 Oil or 0W30 Synthetic in it assuming winter temperatures:
Oct 26, 2011 | Mtd 22" Yard Machine Push Mower
My 17.5 hp MTD yard machine does not try to start
be sure blade isn't engaged, check voltage at battery, depress brake and sit on machine to start, check connection on switch and battery
Jan 25, 2018 | Mtd Garden
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Just trying to find out what mixture of gas and oil i use in the Yard machine 21" Cut Bagger/Mulchar
I think that the engines are Briggs & Stratton and don't need any oil mixing in with the gas. Complete access to the owners manuals is at http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10451
Unfortunately I don't have your model & Serial number so can't provide you with a definitive answer but it will certainly tell you in the manual
If this helps pls leave feedback, if not - let me know so I can try and help some more!
Jan 26, 2010 | Mtd 22" Yard Machine Push Mower
Cant find my model number on my mtd yard machine riding mower and i need a replacement part. it is a rear engine 8 hp 30'' cut
Hi, it should be under the seat. but if it is a engine part you will need the engine make and serial number
Oct 23, 2009 | Garden
Mtd LAWN MOWER PART # 983-04053-0637 DECK Assembly-SD 46" GT Color POWDER BLACK Logo
107 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
