Question about Sony PlayStation Portable (PSP) Console
I have a PSP 1001 and i can't find the error code 80410E80 whut dose it mean and why cant i connect to my wierless router witch is 2 feet away from me and the psp keeps timing out after a min or two how can i fix or change the setting for that. Thankyou
  • Sony Master
  • 2,404 Answers
Sounds like there is something going on with the security key which is usually WEP or WPA and the psp may not be accepting it. Make sure on your wireless router that you don't have a key enabled on it. Best best on most routers. Hold down the reset button for 30 seconds and let go, this will reset your router to factory defaults.
Now that your router has no security on it. Try connecting the PSP to the router again. If it connects then you know the security key was corrupt. Now you can go ahead and put the security key back in. Make sure your PSP is configured to use the key so it can connect.
Posted on May 29, 2011
Unable to get connected to the internet and the app market
On my Iconia when I see this show up it will be from a low power or a poor wii connection. Basically the signal strength is too low which means the speed drops to the point where everything is timing out before it gets loaded.
There are a couple o causes to check . One is too far from the wifi router.the farther away the lower the signal the slower it goes. You have objects blocking the signal such as steel reinforced safety windows or steel mesh in walls. These can block the signal. I have one are where I'm all of 10 feet away and it will barely connect. I have to move about three feet to the side and get ull strength and speed. The orientation of your tablet can effect i you can use a marginal signal or not. Try aiming the edge with the volume buttons towards the wifi. The antenna is oriented in a way that this will slightly improve the signal. The other thing is that your tablet can be fine but your wii router is having problems with its wifi sections. Certain brands will show more errors and then difficulties in connections in as little as a year old (on some about half that). The Iconia has a rather good wifi ability so I wouldn't blame its hardware but would look at the location orientation etc as I have mentioned.
Feb 20, 2012 | Acer ICONIA Tab W500PC52G03iss
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 12, 2012 | NetGear DGN1000 Wireless Router
PSP Error Code 80410E80
That code is related to a failed attempt to connect to wireless internet. The most likely reason is that your security code for your wireless is incorrect. You should check those settings and try again.
If this was helpful, please remember to leave me positive feedback. If you need further assistance, just reply and I will try to help.
May 13, 2011 | Sony PlayStation Portable (PSP) Console
Have a Wierless-G router can not install, tried 3 times. While installing it has very limited range , pc is 4-5 feet away & couldnt pick it up. Any ideas ???
check the wireless settings of the router. try to change the channel of the wireless network.
SSID broadcast should be enabld on the router. It depends on the computer also.
If your router is old then upgrade the firmware of the router. firmware is the software of your router.
Click here for more information about the router
Mar 27, 2010 | Linksys Wireless-G Broadband Router
What mean this error code for psp 2000.
dns error code,unable to connect to your wireless router.
Mar 21, 2010 | Sony PlayStation Portable (PSP) Slim...
What does 8001050f ps3 error code mean?
Playstation released a statement an hour ago that they are aware the network is down... it is a global problem
Mar 01, 2010 | Sony PlayStation® 3 (60 GB) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
NETWORK CONNECTION
try to restart the wierless modem an also restor factory settings on the psp
Aug 29, 2008 | Sony PlayStation Portable (PSP) Console
Problems with my connection
your PSPs are attempting to connect to the net, via a wireless connection device. they are timing out for several reasons.
1:- cannot locate or connect to server.
2:- cannot connect or failed to connect to router or modem.
3:- your PSP is firmware version 1.50 ( this does not support a web Browser )
4:- the firewall if applicable, needs to allow the psp access as a trusted device on the network.
These are a few reasons, why your psp will not connect.
There are others, but these are quite significant.
hope this helps any of you.
Mike @ Compurepair.
information supplied by, 13 year old son ( PSP Addict AKA Rabbit )
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
217 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
