Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
    President:
  • 2,468 Answers
The drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
Posted on May 29, 2011
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
F 02 code. washer won't drain properly
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spins, it is making a terrible loud noise. The washer has always vibrated, but this noise sounds more like a bearing to my husband. It also smelled hot at the end of the cycle. If the...
the noise is a drum bearing, it is pressed on the back of the washer drum, until recently you would have to buy a new drum for around $700.00 but there are a few companies out there selling a bearing kit, just go to EBAY and do a serch for whirlpool duet bearing kit. they are not easy to replace but it can be done by a novice with a few tools and allot of pay chance......GOOD LUCK
Nov 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer makes terrible noise when it spins
do you mean up and down? or when you turn the drum like you are spinning it?if it makes a sound like an airplane takeing off or a train rolling through your house. you have a bad bearing which is a very exspensive repair.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Front Load - Spin Cycle Noise
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Jul 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
705 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
