Question about Electrolux EOB5630 Ultrafan Electric Single Oven
What is the diference between an EOB5630, and EOB5630B, an EOB5630x etc. I have an EOB5630 oven fan element to replace but need to be sure I get the right one. Are these models interchangeable??
  • 24 Answers
I would guess they are the same element in Australia the last letter in electrolux ranges signifies the color or type of clock fitted the B would be for Black ovens the X would be a multi function oven they all have the same fan element
Posted on May 30, 2011
Testimonial: "Thanks for the info. Much appreciated and very quick Have now ordered a new element and will be able to mend myself with the help from this site."
How many elements are there
If you ask how many heating elements is there then my answer is two. Upper heater element with grill heater (1000 / 1900W) and ring heating element (2400W) that is positioned around the convection fan.
Dado
Jun 27, 2014 | Electrolux EOB5630 Ultrafan Electric...
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
The fan works but there is no heat
The problem is usually caused by a faulty oven element.
This is usually located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
Upper cooling fan constantly running
not sure of location but either on roof of oven or at the back close to the fan, but there is a fan start stat that turns the cooling fan on and off. could be stuck in on mode. only cure is to replace
Jun 12, 2007 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
129 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
