Question about HP Pavilion zd8000 Notebook
My laptop was hit by a power surge through my modem, then i had a loud taping sound coming from my front speakers and now none of my speakers are working and my headphone jack does not work either.
  • 30 Answers
Itwouldn get a power surge from a modem because power doesnt go from the modem to the laptop or vice versa, only data signals ... i think you would need to replace the card sound and/or speakers
Posted on May 29, 2011
  • 520 Answers
The power surge probably did damage to your motherboard. if it only blew out your sound then you are lucky. most motherboards dont survive this well. since this is a laptop there isnt anything you can do about it. sorry
None of my buttons will not work it plays very loud. Is there a fix for it?
Are the front panel controls locked out? Look in the owners manual for the procedure.
Oct 17, 2016 | Audio Players & Recorders
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
I just bought a Panasonic SA-PT480, set it up, step by step per the manual, powered through 2 surge protectors( the second surge protector is used to completely cut power to devices that dont need constant...
I can't find a manual for this thing, which I believe is part of the SC-PT480 package.
I'd plug it straight into a wall outlet for further fault isolation and treat it like it has never worked, no assumptions.
Surge protectors only address outside power surges. Overheating, speaker shorts yada yada can still happen. Effective self-protection circuitry activation need not be preceded by smoke and light shows.
When the audio cut off did the unit also die, or did it look otherwise alive? If the former...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Maybe a sleep timer clicked it off. Or if it seems to power on but remains silent some other setting like muting, tape monitor got activated. Or the source audio died. Lots of things.
Feb 23, 2011 | Panasonic Audio Players & Recorders
My stero is not loud enough.
Check for the tape monitor being on or amp mute type function. Larry's Electronics
Apr 27, 2010 | Audio Players & Recorders
Only the front speakers work none of the surround speakers
If you are still covered by the warrenty, then you may be able to get it fixed at no cost.
Otherwise get a qualified technician (I say this to cover my but rather than suggesting that you open it up yourself) to open it up and check the fuses inside.
Aug 17, 2009 | Onkyo TX-SR705 Receiver
Toshiba laptop has no phone line connector. Is there an adapter?
If your laptop has no port for a phone line, there is no modem. I am assuming you want to use your laptop with dial-up internet service. You will need to add a modem(there is no adapter to do this job), there are many connection types for external modems nowadays, PCMCIA, ExpressCard, USB are some examples. USB is the most popular, like the one at the top of this page: http://www.zoom.com/products/dial_up_external_usb.html
Hopefully this helps.
Jun 19, 2009 | Toshiba Satellite M40-S417TD Notebook
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Modem is making loud connection sound itself
unsolder the speaker, its the black can with the hole in it. No other method unless it attaches to the sound card via a cable.
May 02, 2008 | NexxTech NSFTMD1
Laptop speaker
You need to install the drivers for your soundcard. Try to find out what model of soundcard do you have and what version of Windows and try to search for the specific driver on the internet.
You can try these websites:
http://www.driverguide.com/
http://www.soft32.com/c/Windows/Drivers/2-52.html
Here's a tutorial on how to install a driver: http://www.totallydrivers.com/resources/directions_installation.asp
If you still can't hear sound try these steps, maybe it's not from your soundcard:
-Plug in the speakers
-Turn on the speakers.
-Turn-up the volume in Windows and on the speakers.
-Uncheck the mute checkbox in sound control panel.
-Verify a sound should be playing. In the Control Panel, play some Windows sounds. Play a music CD.
-Plug the speakers into the right hole on the sound card.
-Are the speakers plugged into the sound card and not the MODEM?
-Is the sound card installed correctly?
-Is the power converter for the speakers plugged into a wall outlet or surge protector?
-Is the power converter plugged into the speakers?
-Try other speakers or a head phone?
Jan 27, 2008 | Compaq Presario 700 470024-192 Notebook
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
HP Pavilion zd8000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
