Question about Peavey Pv 2600 Power Amplifier
One chanel of my pv 2600 amp is playing very low
    Champion:
  • 243 Answers
As a starting point clean ALL switches on the back of your amp, including the Stereo/Bridge switch then re-check functionality, good luck.
Posted on Nov 07, 2013
3 Suggested Answers
fossildude
  • 832 Answers
SOURCE: amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Posted on Apr 21, 2009
  • 5603 Answers
SOURCE: Can one(1) Peavy PV 2600 amp provide enough power
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
Posted on Sep 16, 2010
Pv 2600 manual como conectar subwoofer
Peavey service is quite helpful and has most parts in stock for good prices. Call them directly at (800) 752-7896
Jun 22, 2014 | Peavey PV 2600 Power Amp
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Clean all back switches first of all, use a cleaning solution spray and give a 3 shot per switch, then push in-n-out several times each one and check amp functionality again.
May 29, 2011 | Peavey Pv 2600 Power Amplifier
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
Peavey 2600 m series shuts off power when turning up volume after about 30 to 40 seconds of playing and takes about 2 minutes to reset
Sounds like the thermal cutout is sensing over temp. Make sure there is FREE airflow around the unit. If it is in a cabinet, install vent fan(s). This amp will throw out a lot of heat. Make sure cooling fins have airflow. Cables can block the airflow... check for that possibility. Repeated thermal cycles will eventually cause failure of components.
Mar 27, 2011 | Peavey Pv 2600 Power Amplifier
Can one(1) Peavy PV 2600 amp provide enough power for two(2) Yorkvilles 15" 300W full range and two(2) Yorkvilles 18" 400W subwoofers?
Sep 15, 2010 | Peavey Pv 2600 Power Amplifier
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
Do you know what regulator/ rectifiers are used and their numerical values so i can repair my fried pv 2600 these are the row along heat sink small black ones 2 pin and 3 pin cheers
7815 and 7915 plus and minus regulators specifically. Diodes fr the 15 supplies are 1N4001 but you can use 1N4007 or anything in between.
Big power rectifiers are 2504's... which are probably 25 amp 400 volt modules.
Jul 18, 2010 | Peavey Pv 2600 Power Amplifier
Amp will not come on
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
77 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
