Question about LowerPriceUSA.com 3-Pack LG Cookie KP500 Combo LCD Screen Protector for LG Cookie KP500
How can i extend ring time for incoming calls
How do I extend the ring for an incoming call
Extending your ringing tone You can change the length of your ringing tone by typing the below code into your phone.
**61*(mailbox number)**(number of seconds you want it to ring for)# send You can choose between 5 and 30 seconds. The standard ringing time is 15 seconds.
If you don't know your mailbox number it's just your normal mobile number with '5' added after the prefix. For example, 087 5 1234567.
Apr 12, 2015 | Cell Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
My phone only rings 3 times for incoming calls
There is no such option in motorola as i know to extend duration of incoming ring.
Apr 28, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Problem with incoming call ring alret
It may change due to your profile or because of your memory card (if u have one).
Apr 22, 2009 | Nokia N73 Cellular Phone
Extending number of rings before voice mail engages
Is the caller being transfered to the ext or is it on incoming calls?
Tony
Aug 23, 2008 | Toshiba DKT-2020-SD telephone
Wont accept incoming calls
this happened to mine , I never had aproblem before than one day ??? didnt work . I changed phone jacks ?? dont know why ??
1. Try disconnecting all phones in the household except the phone being affected.
2. Do a test call to see if the unit rings.
3. If the phone rings at this time, begin reconnecting all the other units one at a time. If the affected phone does not ring again, this is an indication that there are too many phones in the loop.
4. If possible try testing the phone on a totally different phone jack (friends or neighbors) to check if the same thing happens.
Also make sure the phone is not connected through an external answering machine, caller ID box, fax machine, computer, splitter, or defective DSL filter. If so then connect the telephone cord directly to the telephone jack and make a test call.
Jun 30, 2008 | Uniden Cordless Phone
LowerPriceUSA.com 3-Pack LG Cookie KP500 Combo LCD Screen Protector for LG Cookie KP500 Logo
44 people viewed this question
Top LowerPriceUSA.com Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a LowerPriceUSA.com Cell Phone Expert? Answer questions, earn points and help others
