Question about Frigidaire GLEQ2152ES Electric Dryer
Where is the house fuse located on the dryer - Frigidaire GLEQ2152ES Electric Dryer
    Master:
    Sergeant:
  • 385 Answers
No fuse in dryer, the fuse or circuit breaker is in your house main fuse box.Hope this helped.
Posted on May 29, 2011
Just got electric dryer #FAQE7011LW0 dryer will not heat manual says check fuses but does not say where they are located
The fuse they are refering to is the fuse/circuit breaker for your house wiring in your house fuse box/breaker panel
Sep 18, 2011 | Frigidaire Dryers
Where are fuses located on Whirlpool electric dryer?
Check the internal thermal fuse, which is located within the back panel. The fuse is about an inch long and oval-shaped.
If your dryer is not getting hot, the thermal fuse may be blown. Instead of calling an expensive repairman, you can replace this simple part yourself in less than an hour. Make sure you purchase the correct replacement fuse for your make and model of dryer. Your owner's manual should have a list of compatible part numbers. You may also be able to order a replacement directly from your dryer manufacturer's website.
Things You'll Need
  • Hex nut screwdriver
  • Replacement thermal fuse
    • 1 Disconnect the dryer from the electrical outlet. Remove the dryer vent from the back of the dryer by loosening the retaining screw on the clamp attaching the vent to the dryer's exhaust port and sliding the vent off of the port.
    • 2 Remove the hex nuts holding the dryer's rear panel in place. Slide the panel off to the side of the dryer. Locate the thermal fuse on the heating element housing on the right side of the dryer. The fuse is an oval-shaped part located near the top of the housing.
    • 3 Slide the thermal fuse wires off of the contact terminals on the fuse. Remove the hex nut holding the fuse in place and remove the old fuse.
    • 4 Place a new fuse on the housing and replace the hex nut. Reconnect the thermal fuse wires. Replace the dryer's rear panel and plug the dryer back into the electrical outlet.
Jun 12, 2011 | Whirlpool LER8648P Electric Dryer
Where are the house fuses in the manual located in they dryer
The fuse box is either located in the garage or basement of the house.
May 07, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Will not start
The problem is likely a blown thermal fuse.Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Dec 18, 2010 | Whirlpool LER5636P Electric Dryer
Thermal fuse location on a 110.9597590110 gas dryer
The model number of your machine doesn't seem to exist but the thermal fuse, whether dryer is electric or gas, is always located on the blower housing together with the thermistor or cycling thermostat depending on the model of the dryer. The blower housing is located at the rear of the dryer if the lint filter of you dryer is located on top of the cabinet and can be accessed by removing the rear panel.
The blower housing is located on the front right bottom of the dryer if the lint filter is located on the door. It can be accessed by removing the kick panel.
Kick Panel Removal
Once the kick panel is removed, remove the lint chute to expose the blower housing and the thermal fuse.
Sep 30, 2010 | Kenmore Dryers
WHERE IS THE HOUSE FUSES LOCATED?
If you're reading your manual and it refers to "house fuses" they are the fuses or most likely now circuit breaker in your "house" that supplys the voltage to the dryer. In other words, check your main electric panel for a tripped breaker or blown fuse.
Jul 17, 2010 | Frigidaire FGQB4000F Dryer
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Push Button to start and nothing happens.
Hi, The first thing you want to check is that the dryer has power to it. Then check the non resetable fuse. On most models the fuse is located in back of the dryer behind the rear panel.
Once you remove the rear panel, you will see the fuse located on the blower housing (White in color). Take continuity on the fuse. If the fuse has continuity, it is ok. If you an not access the fuse from the back, remove the front lower panel and the fuse is again located on the blower housing.
Other possibilities are door switch, timier, & motor. The fuse is most common problem!!
If I can help further, please let me know.
Thanks
Vic
May 12, 2009 | Kenmore 63942 Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
102 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
