Question about Amcor PLM12000E Portable Air Conditioner
Water fills the receptacle about every 2-3 hours. It only had to be emptied once or twice a week before. It's only 3 years old. Filter is clean and unit is set up properly. Any advice? It's a 12000E.
  • manz824 May 29, 2011
    I just don't understand why this didn't happen when the unit was new. Same house, same room, temp and humidity don't vary much year to year.
    President:
  • 2,080 Answers
The amount of water that drains into the condensate collection bucket will vary widely based upon the ambient temperature and humidity levels.
If the current temperature and humidity levels are relatively high, then it is not at all unusual to have to drain the receptacle multiple times per day.
This water is being pulled out of the air in the room and is a sign that your unit is working properly.
When the ambient temperature or humidity levels are lower, then a week or more may pass before you have to empty the receptacle.
I hope that was helpful to you, good luck.
Joe.
Posted on May 29, 2011
  • Joe2
    Joe2 May 29, 2011
    Unless you live in a climate controlled underground missile bunker, the ambient temperature and humidity levels will vary significantly both from day to day depending on the local weather, and from season to season.
    It may just be a little warmer and more humid lately in your area right now and the unit is pulling a lot more of the water out of the air. Or perhaps you altered the settings on the machine slightly and it is just running more often.
    In order for the unit's self evaporation funtion to operate correctly, make sure the discharge hose is properly fitted to the window.
    Here is a link to an owner's manual for a similar unit:
    http://www.sylvane.com/images/prodphoto/...
    To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
    You may need ADOBE READER installed on your computer to read PDF documents.
    You can download this free at WWW.ADOBE.COM if necessary.
    Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
    See page 5 of the manual for detailed instructions and illustrations about proper discharge hose positioning.
    Good luck.
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Tip
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
My car started over heating and I stopped on the side of the road and poured water into my brake fluid instead of my radiator and then drove it straight hone abou 7 mile
Brake fluid is hygroscopic (pulls in moisture from the atmosphere). Putting water in there is definitely very bad for the system because water will readily mix with the fluid and can actually boil as you made a hard stop.
First thing to do is remove the fluid from the reservoir using a turkey baster or siphon. Re-fill with fresh fluid, then bleed the front wheels, doing that 'till the master is nearly empty, Re-fill and do the same at the rear brakes. Repeat entire procedure twice. Unlike normal bleeding, you don't add while you are doing the procedure but run the reservoir nearly empty, only adding fluid when it comes close to empty. And, you begin at the front instead of the rear. Do not let the reservoir become empty or air will enter the system.
After completing the flush, it's a good idea to empty the reservoir and re-fill once or twice in the next few weeks just to make sure no more water is in there.
You didn't mention what you did about the overheating but make sure that's taken care of asap or the least of your problems will be the brakes!!
Jul 30, 2011 | Saturn Aura Cars & Trucks
Hi, my intex salt water system is not generating chlorine. There is no error codes and my water tastes super salty. Can you please let me know what might be the problem. It is brand new and was working and...
If the water tastes salty then there is too much salt in it. The amount of stabilizer is very important too. If it is low then any chlorine the generates will be gone when the sun hits it. Stabilizer is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be dissipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Jul 07, 2011 | Intex Automatic Salt Water System for ...
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
Asko dishwasher filter at bottom of unit collects food waste - how do you clean?
Keep in mind that there are two filters:
Coarse filter
The coarse filter collects large food particles
which cannot pass the outflow pump.
Lift out and empty the coarse filter as
necessary. Don't forget to replace it!
Fine filter
The residue which collects on the fine filter is
automatically rinsed off with each wash. The
fine filter should still be cleaned once or
twice a year.
1. Remove the fine filter by first turning the
filter's tubular strainer anti-clockwise and
then lifting it straight up with the coarse filter.
2. Clean with a dish washing brush. Ensure
that the edges are properly sealed
Download the manual and go to cleaning page.
Jun 05, 2011 | Dishwashers
I have a Duracaraft Humidifier DWM-250 series. It was working perfectly fine for 2 days. Then it stopped producing mist. I have cleaned the heating element, not used it for almost 24 hours just in case...
It may have a scale and mineral build up, prior to using bottled water.
To clean it, empty the tank of any water that's already in it and fill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the solution to sit in the tank for 30 minutes, before turning the humidifier ON. Once the unit is ON allow it to run for at least 30 minutes, then check to see it if it's misting, by holding your hand in front of the nozzle. If it is, allow it to run until the tank is 3/4's empty. Turn the unit OFF, unplug it and pour out the remaining solution. Then fill the tank with Bottled Distilled Water and run the unit for one hour. This will allow enough time, for the Distilled Water to flush the system. After that, fill it again with Bottled Distilled Water and use the humidifier as you normally do.
If it didn't start misting when you turned it ON. Allow the solution to set for 3 hours and then try it again.
Hopefully, this will solve your problem. It does 95% of the time. Please let me know if it worked for you. Thanks.
May 05, 2011 | Heating & Cooling
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 | Irons
Amcor PLM12000E Portable Air Conditioner Logo
106 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
