Question about Westclox Vanguard (129061) Clock Radio
Where can I find the manual for Westclox 129061? The time in my clock is running to fast. Is there a way to slow down it a little bit?
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
Instructions for westclox bluetooth stero am/fm clock radio
Google search your manufacturer make and model and the word
manual. If one is available, you can find it in the search
results.
Mar 23, 2015 | Westclox Audio Players & Recorders
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
Polaris grandfather clock runs slow need to adjust time up
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Nov 17, 2012 | Watches
I have 3 westclox clocks I have lost the instructions to set them. atomic clock Westclox 70026 cannot change the zone nor can I set the time to alarm
Manual on the link below.
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Oct 13, 2011 | Audio Players & Recorders
Are Westclocks made in the usa?
Westclox clocks--and, at one time, watches--were once made in the United States. However, especially since the purchase of the Westclox brand and assets by a holding company in 2007, and the general disorganization that followed that acquisition, it's likely that all production has been moved offshore.
From about 1919 through the early 1980s, Westclox products were also made in Canada at their factory in Peterborough. Westclox also had a large factory in Scotland that manufactured over 50 million clocks between 1948 and 1988.
Jul 15, 2011 | Watches
I inherited a grandfather clock which runs slow
Mar 23, 2009 | Watches
Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Apr 22, 2008 | Westclox Audio Players & Recorders
Westclox model 22717
Hi faulkquarter
I take it that the clock displayed with this problem if not a 22717 model. The one I have sighted is a digital clock. Generally, you need to hold down the "time" button and also press the "hours" and "mins" buttons at the same time to set the time. If this is not how your clock appears, please give me the button names and I can write a method of changing the time for you.
regards
Graeme
Apr 14, 2008 | General Time Corporation Westclox Bell...
Westclox Vanguard (129061) Clock Radio Logo
82 people viewed this question
Top Westclox Audio Players & Recorders Experts
Joseph Hoffmann
ray gallant
Tom Chichester
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
