Question about Midland Radio Communications
I have a Midland 75-822. I want to know how long does it take to recharge the 8 batteries in the battery pack. Does the light change from red to green, or is there some other indicator that tells me that the batteries are fully charged
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Basically they should charge in 10-12 hours. If not its got defective batteries or is not charging properly.
Posted on May 29, 2011
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
http://www.manualslib.com/manual/103192/Midland-Gxt300.html?page=6#manual
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
How could i change its batteries?
  • Your radio, Midland LXT110, utilizes a NiMH rechargeable battery pack or 3AAA batteries. I have a similar set and when the battery pack runs out I just use regular AAA rechargeable batteries. They are more economical. To change the batteries in general follow these steps.
  1. Remove the back clip.
  2. Now remove the battery cover by pushing down from the top center of the battery cover and slide it off.
  3. Replace batteries observing polarity.
  4. Replace the battery cover.
  5. Replace battery clip.
Regards, Tony
May 17, 2011 | Midland LXT110 Two Way Radio
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
Can i get replacement rechargeable battery packs
The best deal that I found on your batteries is on eBay, and you can follow this link to the sale:
http://cgi.ebay.com/2-Midland-AVP-7-Rechargable-NI-MH-Battery-Packs-BATT5R-/160368242370?pt=2_Way_Radios_FRS&hash=item2556b12ec2
If you're not an eBayer, you can also purchase the batteries here (for a bit more):
http://www.123radios.com/BuyItNow.asp?PID=1222
Bill B.
Nov 15, 2010 | Midland LXT310 2-Way Radio
Midland rechargeable battery packs won't recharge and vibrate
You might contact Midland Radio Corp to see if they have a fix for your problem. If I had to give an educated guess I would say the batteries need jump started (which sometimes happens when they are new and too low of charge; or there is a problem where they contact the charger and they are not receiving a full charge; or they are defective. I am sure the factory would be happy to assist you in solving the issue.
Here is there info: http://www.midlandradio.com/contact_us.asp
MIDLAND RADIO CORPORATION
5900 Parretta Drive
Kansas City, MO 64120
P. 816.241.8500
F. 816.241.5713
Email: mail@midlandradio.com
Nov 07, 2008 | Radio Communications
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Radio Communications Logo
269 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
