Question about Video Game Consoles & Games
I tried to install update but cant get it to install it and each time i start the ps3 it tries to install it but comes up with error 8002F1F9 can you tell me why
  • 2 more comments
  • martinrother May 30, 2011
    i tried a 60gb hdd in it from an old ps3 but came up check signal and it turned itself off.
    i am wondering if it only part downloaded update due to internet connection could this be why it isnt installing fully it installs up to 90% and then comes up with error code
    checked the band is tight but still installs to 92% then comes up with code tried different hdd still doesnt work
  • martinrother Jun 04, 2011
    it still not working checked all you said to
    Genius:
  • 1,098 Answers
Hi there.
The cause of this issue is not really known. You need to update the console.
To update you will have to access the recovery menu , if it won't let you you can swap in a different hdd from an old laptop ( you don't have to format it and won't lose any data on your hdd ) just slide it in without tightening the blue screw this will allow you to access the recovery menu , then while at the menu swap the original hdd back and then update'
You can also buy a new hdd , or after removing the one you have now use an external enclosure and format it then reuse it .
Let me know if you need further assistance.
Posted on May 29, 2011
  • Ivy  Cada
    Ivy Cada May 30, 2011
    it could be a lot of reasons actually but normally it is due to hardware's fault. Try to open it up and check the connection of the wifi/bluetooth board. There is a ribbon cable connecting to the main board, make sure it is tightly connected.
Hi, how do i fix the error 8002f1f9 that keeps on showing when iam trying to install update on my play station three
Have you tried to install the update via USB thumb drive? I recommend installing the update from the "safe mode" menu. I will post a link to get you started. Good luck! ^^
How to Update PS3 with USB Safe Mode
Nov 03, 2015 | Sony Playstation 3 (PS3) Console
ERROR 8002F1F9 DURING AN UPDATE THROUGHT PS3 **** (NOT INTERNET) EVERY TIME I OPEN THE CONCOLE IT TRYIES TO UPDATE AND STOPS AT 55%
From my knowledge on ERROR 8002F1F9, you need to try the system recovery menu and if that doesn't work you need to contact Playstation customer support: 800-345-7669.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Sep 14, 2011 | Video Game Consoles & Games
PS3 ERROR 8002F1F9
My friend had that error code 8002F1F9 before and he sent his PS3 to www.videogame911.com. I have also sent all my systems there and they are returned in better then new condition. Good Luck!!
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
I'm updating my playstation but it keeps failing and it said to cantact tech support. The error code is 8002F1F9
I think your problem is due to a Firmware glitch. Try reformatting your hard disk under 'System Setting'. After that, download the latest Firmware update to a USB flash drive, and update it via Storage Device under 'Update'. This should get your Ps3 up and running properly in no time I hope this helps! - Omn1cide
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
The install of the update 3.50 gets stuck at 70 % and I get error code 8002F1F9
i have this problem try doing this----- dowload the update on your USB flash drive from your computer and then plug in your USB flash drive into the ps3 the and it will automatically be installed onto uour ps3 SIMPLE!!!
Sep 22, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: trying to update software and keep getting the 800...
You will need an extra 2.5" HDD. use a laptop HDD.
So we all know with this error, it won't allow you to enter in the recovery menu because it would try to re-install the bad 2.8 update firmware again and again once it turned on.
1. So what I did was I swapped the laptop HDD into the PS3, it won't be able to read the HDD but it will allow you to enter the recovery menu now.
(for those who do not know how to get into the recovery menu, here is the instruction http://boardsus.playstation.com/playstation/board/message?message
.uid=39144801
2. Once I'm in the recovery menu, I took out the laptop HDD and put back in the PS3 HDD.
3. I also downloaded the 3.01 firmware from the PS website and uploaded into my USB drive and put that in the PS3 slot.
4. At this point, you want to select "system update" and update to the 3.01 version.
For some reason, the first time doing this the system froze at 67% with a new error (but i didn't write down the code). So I had repeat step 1 and 2, but this time when I put back in the PS3 HDD I chose "restore file system" without having to do the system update again. Then it gave me another error at around 65% that said the disk is corrupted and tell me to press OK to format the disk. After it formatted, it automatically install the 3.01 version and the system is fixed.
May 07, 2010 | Sony Playstation 3 (PS3) Console
Stuck in the update loop with error 8002f1f9
I had the same problem... Just fixed it today..
Just before I had the update loop problem, my bluetooth on the PS3 went. I could only use the controller whilst connected to the USB port.
I replaced the bluetooth/wifi board
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Need to fix a ps3 with 8002f1f9 error code. where
PS3 has a **** poor wireless card i would run a cable for your internet connection.You can DOWNLOAD the update and get instructions here
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code 8002F1F9
this error code is due to internal error caused by us ............
ERROR CODE 8002f1f9
has a solution you can download the repair guide to fix this.. your problem can be solved to do so ...... Click Here to Get Solution .......
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
System update error 8002f1f9 won't finish installing it updated just wont install. Can't do anything with it. Tried recovery menu and cant get it it just starts installing again. Please help
u might of turned it off when it was installing and u might get corrupt data soo make a new profile and update it without turning it off . if it still doesnt work recover fully and make a new acc and try it there. this happened to me too good luck!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
